Old 11-26-2008, 01:09 PM   #1
BlkdOut00Alero
BlkdOut00Alero is on a distinguished road
crappy radio reception
does any1 think that an aftermarket will give u crappy radio reception....because the wires look goods to me and it may be time to replace the antenna itself on the back window.....(is that where it is)??
BlkdOut00Alero is offline   Reply With Quote
Old 11-26-2008, 03:12 PM   #2
Justin081
Justin081's Avatar
Justin081 is on a distinguished road
Send a message via AIM to Justin081
ya it could be the antenna in the back window. thats why mine doesnt work. whoever had the car before me messed up the antenna and defrosted lines in the back window and now i have to replace my whole window.
http://www.fquick.com/Justin081
Justin081 is offline   Reply With Quote
Old 11-26-2008, 04:13 PM   #3
Vinalero
Vinalero's Avatar
did the reception gone bad way after you installed your aftermarket radio, or was it bad the moment you put the new Head unit in?
Alero's have an antenna booster wire that you need to connect with the remote wire on your HU. Reception will be clear after that. I don't remember the color of the wire though.
Old 11-28-2008, 11:12 AM   #4
Mischief007
Mischief007 is an unknown quantity at this point
Send a message via MSN to Mischief007
There is a module just underneath the parcel shelf that the antenna wire runs through. If it goes bad, it takes the rear defrost with it too. Check for power to your rear defrost. It is all one module and not cheap.
??,??? km
??,??? miles
Mischief007 is offline   Reply With Quote
