Old 12-30-2007, 11:24 PM   #21
AJules
AJules's Avatar
AJules is on a distinguished road
Originally Posted by YALEROYNOT View Post
not hard at all.
get the money for the install return the rears and buy a sub
wow.... it's definitely not easy at all
Edit: okay, the fronts are pretty easy
rears... ehh... seem very difficult
guess that's why you said buy a sub though...
AJules is offline   Reply With Quote
Old 12-31-2007, 10:57 AM   #22
The fronts are worse as you need to run new wire to the door. Going thru that grommet is a pain IMO. Well unless you have a fish tape.
The rear is easy. You already have it apart to run the power wire. So you just toss the speaker wire in with it. Ditto when running new wire to the front speakers from the rear of the car for an amp. So very simple.
I do it the hard way though to make sure its perfect.
Power down one side, speakers up the other. RCAs down the center Ive got 2 runs of Stinger Experts and had an optical run you couldnt even see.
Old 12-31-2007, 01:31 PM   #23
AJules
AJules's Avatar
wait hold on, I got my fronts in last night and I didn't have to run any wires. I just hooked em up to the old ones and they worked perfectly
the only issues I has were trying to get them to screw in.
The rear speakers are what I've had trouble getting to
how the hell do you even get to em?
does basically everything behind the rear seats have to come out?
Old 12-31-2007, 07:23 PM   #24
Running new wires isnt hard.
Removing the rear speakers is a bit more involved.
I take it all out. I take the rear seat out and the rear panels. Then lift the rear deck card out.
If you are having troubles or just need it done contact Terry @ Sound Solutions in Florence KY. He will get you hooked up at a very reasonable rate. Tell him I sent ya, might get a better deal too.
Old 12-31-2007, 07:40 PM   #25
AJules
AJules's Avatar
I just used my original wires
for me the rear speakers ended up being pretty easy
I just hadta figure out what I was doing
I didn't have to take out the seats or any panels, I just popped out the covers unclipped the speakers and they came right out
Old 01-01-2008, 02:50 PM   #26
I'm assuming there are 6x9s in the back, but what are stock in the front?
Old 01-01-2008, 03:06 PM   #27
4x6 In The Fronts
Old 01-01-2008, 03:22 PM   #28
thanks.
Old 01-02-2008, 02:48 PM   #29
So after ready all this it seems that I should just get rid of my 6x9's in the back because the subs that I have in there are distorting them anyway? That saves me some bucks. Hope that I can get the same level of sound though from just the fronts. I have two 200 watt amps that I'm not using now anyway so I guess I could use one on the drives side and one on the pass side.
Old 01-02-2008, 07:28 PM   #30
Trust me, with some good 5.25 or 6.5's in the front, tweets int he sail with proper amping, you will in no way ever need the rears or miss them.
Old 01-02-2008, 08:30 PM   #31
remove the rears to get better sound out of the sub with out putting the seat down. my 6.5 door pods are in the works.
Old 01-04-2008, 07:53 AM   #32
Some one got the link to the thread about fitting 5.25 or 6.5 in the 4x6 hole in the front? I'd be willing to try this. When I use my DVD player I always fad it to the front anyway, and I kind of like the sound.
Old 01-04-2008, 09:02 AM   #33
im going to glass door pods for mine.
here is a thread that might help you
http://www.aleromod.com
Old 01-04-2008, 09:59 PM   #34
Its not bad. What I did was fairly simple, just used the wrong material
Take some 1/4" plywood. Cut the base. Then cut the baffle. Use dowel Rods cut as needed to create your angle. Hot glue it together. Use speaker grill cloth and fiberglass for the first layer followed by 2 layers of glass. Done.
I got my set here you can have if you want them. Not perfect but works. $10 shipped.
I used like 3-4 sheet metal screws to attach each one. No hacking of the door needed. Easy switch back to stock
Old 01-04-2008, 10:02 PM   #35
Post a pic of those! ASAP!
Old 01-05-2008, 10:00 PM   #36
bah tomorrow?
