Old 11-30-2003, 12:22 PM   #21
Final-Reality
You've never had your tires rub niach? I've had my left tire rub the back of the fenderwell when going up the ramp in my parking garage a little too quickly... busted the damn plastic on it too... Although my tires are stock width, 215, they're a little bit taller than stock, a 65 aspect ratio instead of the stock 60
Old 11-30-2003, 12:36 PM   #22
evilinside09
those aleroperformance coilovers listed on aleroupgrades.com aren't being made anymore? anyone know who i could get in contact with to get a set made now that i have money?
Old 11-30-2003, 09:35 PM   #23
Naich
The Founder
Naich's Avatar
Final,
Nope, I've never had my tires rub. The only problem I have is pulling into my parents driveway... it is on a wierd angle... the street is going uphill, and the driveway is sort of twisted... so when I pull in, it is fine, but backing out, my front end always scrapes on the ground.
Old 12-01-2003, 05:49 AM   #24
AleroSS
how long does it normally take springs to settle? and how much difference from the first day vs settled state is there?
Old 05-06-2009, 12:05 PM   #25
jackal2000
jackal2000's Avatar
i are thread jesus.
just want to update this thread because even though i said i was going to get intrax back in the day, i ended up with eibachs and i am switching to sprints as soon as i get back.
Old 05-06-2009, 12:27 PM   #26
nice 6 years ago lol
Old 05-06-2009, 12:40 PM   #27
jackal2000
jackal2000's Avatar
this is one of the oldest threads on the board.
Old 05-06-2009, 02:02 PM   #28
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
back when EVERYBODY was a n00b. WOW. good jorb.
Old 05-06-2009, 02:03 PM   #29
wow, i thought other members were bad...
Old 05-06-2009, 02:23 PM   #30
Bad99Olds
New and Improved
Bad99Olds's Avatar
Bad99Olds is on a distinguished road
Send a message via AIM to Bad99Olds
Guys cut him some slack, hes bored and lonely.
Bad99Olds is offline   Reply With Quote
Old 05-06-2009, 02:24 PM   #31
to bad, go give him company
Old 05-06-2009, 02:25 PM   #32
jackal2000
jackal2000's Avatar
stop whoring my thread.
Old 05-06-2009, 03:07 PM   #33
Bad99Olds
New and Improved
Bad99Olds's Avatar
this thread is pointless and old. like you.
Old 05-06-2009, 06:27 PM   #34
kevin1114
kevin1114's Avatar
kevin1114 is on a distinguished road
If I drop, can i install Spacers as well??? and how low can i go???
Take Life's Curves Sideways, and Drift!
kevin1114 is offline   Reply With Quote
Old 05-06-2009, 08:37 PM   #35
Good God, This thread was started almost the same day I joined Aleromod, right after the big site crash
Old 05-06-2009, 10:59 PM   #36
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
depends, if your baggin it, you dont want spacers
that is if your going for the wheels tucking in thing
otherwise i dont think it matters if you use spacers for a wider stance, even though the aleros have a nice wide stance to begin with
Old 05-06-2009, 11:21 PM   #37
kevin1114
kevin1114's Avatar
So spacers for wider stance + Eibach springs is a good set up then
Old 05-06-2009, 11:27 PM   #38
no a good setup is eibachs with the right offset wheels so you don't need spacers........
Old 05-07-2009, 02:53 AM   #39
Spilner521
Boost Guru
Spilner521's Avatar
The man speaks the truth^^
Although I prefer a lower drop than the Eibachs give, they are the stiffer springs and should handle very well.
Old 05-07-2009, 10:16 AM   #40
01OldsAleroGt
01OldsAleroGt's Avatar
01OldsAleroGt is on a distinguished road
Send a message via AIM to 01OldsAleroGt Send a message via MSN to 01OldsAleroGt Send a message via Yahoo to 01OldsAleroGt
how does the alero handle with eibachs on KYB GR2's
2001 Oldsmobile Alero GL Sedan LA1 3400 SFI V6
Nickname : Midnyte
01OldsAleroGt is offline   Reply With Quote
