Old 10-28-2008, 11:42 PM   #21
Spilner521
Boost Guru
Spilner521's Avatar
Originally Posted by AlbinoMonkeyRat View Post
this is how the not-so-common true duals on a 4-banger are though. boosted applications which don't require a whole lot of back pressure would definitely benefit from a 4-2-1 header, minus the 1.
No setup requires backpressure. Backpressure is the last thing you want in any exhaust system, whether it's a naturally aspirated 1.5L Honda Fit or a twin turbo 7.0L LS7 from a ZO6.
On the N/A setup you'll want to keep the pipe diameter the right size to keep high exhaust velocity. On the turbo setup...as big as you can fit. Supercharged...somewhere in between.
Originally Posted by DansGen1Alero View Post
and one of his cars is Lamar's 95 civic twin turbo (not street legal)
Like I said:
Originally Posted by Spilner521 View Post
Some people aren't as knowledgeable as they may think, whether they've built cars or not.
Old 10-28-2008, 11:52 PM   #22
Haha, the backpressure myth. Good stuff.
It's all about exhaust velocity people. You want the exhaust to aid in sucking the heated gases out of the cylinders.
Old 10-29-2008, 12:09 AM   #23
DOHC_tuner
DOHC_tuner's Avatar
I got a header, high flow cat, a magna flow muffler, and just installed a long 20 inch resonator and the car loves it. The car feels a bit better with the resonator.
Old 10-29-2008, 12:14 AM   #24
DOHC_tuner
DOHC_tuner's Avatar
Your right but this guy I believe, becasue he actually has/had a shop that built them for some circuit, plus he is like 34 and been doing it for well over 10 years.
The shop I think he worked for is this myspace page
http://profile.myspace.com/index.cfm...id=210 517188
and I dont know much about exhaust or turbos, so of course someone could probably debate his knowledge.
Dam that Integra with the JDM conversion is SWEET!
Old 10-29-2008, 07:34 AM   #25
DansGen1Alero
DansGen1Alero's Avatar
DansGen1Alero is an unknown quantity at this point
Send a message via AIM to DansGen1Alero Send a message via Yahoo to DansGen1Alero Send a message via Skype™ to DansGen1Alero
No setup requires backpressure. Backpressure is that last thing you want in any exhaust system, whether it's a naturally aspirated 1.5L Honda Fit or a twin turbo 7.0L LS7 from a ZO6.
Like I said:
So then you are also reffering to yourself then, Just becasue you have built one or more cars how do you think you are more knowledgable?
www.myspace.com/dansgen1alero
www.nicedreamscc.com
"Vinyl belongs on the side of a house not on a car"
DansGen1Alero is offline   Reply With Quote
Old 11-01-2008, 05:16 PM   #26
Spilner521
Boost Guru
Spilner521's Avatar
I didn't say I was more knowledgeable, I just posted about something I knew to be incorrect. I'm sure there's a plenty of people that are quite a bit more knowledgeable than me, but using my own hands-on experiences and from research I've done mixed with a little common sense, I've learned a lot about a lot.
About that twin turbo Civic, I didn't read into it very far. I just looked at the pics now and it's a pretty sick setup. When someone says "twin turbo Civic" the first thing you think is not RWD twin turbo V8
