Old 03-05-2009, 12:39 AM   #21
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
im just weary of capacitors
Old 03-05-2009, 12:49 AM   #22
guiguilandry
guiguilandry's Avatar
Originally Posted by Misuseofyou View Post
Your head unit should have the ability to turn off your subs. No offense but you shouldn't be screwing around with electricity.
x2....
Custom or Nothing...
www.demonautosport.ca
Old 03-05-2009, 01:04 AM   #23
mach3
mach3 is on a distinguished road
Sounds like you have a lot to learn my friend. My recommenation to you is to at least have some one around who knows what they're doing if you decide install your own system. Many things can go wrong afterwards if it's not wired properly and you're going to be kicking yourself with all the trouble shooting later.
mach3 is offline   Reply With Quote
Old 03-05-2009, 10:28 AM   #24
an audio professional told me i could switch the power cable i was a little iffy about it, promised myself to get a switch with RUBBER round the switch, but i heard that discharging a capacitor was dangerous less done right so i gave it up,
the switch will be used to turn off the amp and sub when around GFs parents
whoever told you thats NOT a professional and should STFU and die. They are an idiot... And is the last person who should be giving advice.
YOU DO NOT PUT A SWITCH ON THE 12V POWER LINE.
I cant stress that loud enough...
Old 03-05-2009, 11:22 AM   #25
bonez1203
bonez1203's Avatar
bonez1203 is on a distinguished road
here you will find everything you will ever need to know!make sure you read and learn before you end up getting hurt or burning up the car
http://www.bcae1.com/
bonez1203 is offline   Reply With Quote
Old 03-05-2009, 11:43 AM   #26
Ghadsphi
The Drunk
Ghadsphi's Avatar
Ghadsphi is an unknown quantity at this point
You should be warry of capacitors. They're designed to store energy and discharge it. Think of a 9 volt battery on your tounge. It dispences it's energy over time... Now some capacitors are designed to hold gods third leg and discharging it wrong will give it to you all at once we're talking 1 INSTANT you just got violated by god, please fall down and don't get up.
`03 Alero GL 2.2L Ecotec
Ghadsphi is offline   Reply With Quote
Old 03-05-2009, 01:54 PM   #27
GoldStar611
GoldStar611 is on a distinguished road
To be honest a 1/2 or even 1 farad cap is more trouble than it's worth, having to deal with charging and all. Just leave out the cap, IMO. Aftermarket radios have a output labeled remote, put a switch in between that. My stock radio didn't have a remote wire so I wired up to a switched fuse and put a switch in between that.
GoldStar611 is offline   Reply With Quote
Old 03-05-2009, 02:54 PM   #28
Like Ryan put so boldly...LOL Its not a good idea at all..yes it can be done but it isn't necessary. More importantly, if you put a switch on the main power for the amp you will be discharging the capacitor every time, and as soon as you flip the switch you will be zapping it with a ton of power at once..Not good unless you want to buy 70 dollar caps all the time. I have a cap in my car and no switches of any kind on the main power for the amp. Big NONO
Old 03-06-2009, 11:57 PM   #29
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
i realize that guy is an idiot, and i realize not to do that, hence i havent? and yes i know why to be weary of a capictor, thats why i been trying to understand how to safely discharge them, but a lot of smart$$$s just tell me to put my hand across it
Old 03-07-2009, 08:53 AM   #30
Ack, just lick it like a 9V battery...
To answer your question Im not 100% sure on that myself. I have a couple questions regarding caps I need to research. How to safely discharge and how to test them.
Old 03-07-2009, 09:27 AM   #31
OMG if you lick that thing post on youtube...LOL
Old 03-07-2009, 09:32 AM   #32
It will be right up there with the Habenero pepper kid...
http://www.youtube.com/watch?v=L8ip5oGlMfU
Old 03-07-2009, 10:03 AM   #33
i'd think the biggest trouble of switching the power line... would be how to connect a wire thats, at least 8ga, to a switch. it'd take a good electrician to pull that off, and they'd know better.
essentially, what your looking to do is use the remote wire on a switch.
from headunit(remote wire)-----switch--------amp
this will allow you to turn the amp on and off, but only when the car is on. so if by mistake you leave it on when you leave the car, it turns off anyway.
Those remote wires are there for a reason, and for this exact reason. (on both sides. the amp side and the headunit side. they built it there to be used, don't ignore it)
and my buddy who was somewhat of an audio/electrical genius always told me, to just connect a small 12V lightbulb to the capacitor. something that requires very little current. When the bulb goes out, the current is gone. And led would work too. And since they run only .02a, that thing will be VERY discharged when it goes out... it'll just take a while.
Old 03-07-2009, 10:20 AM   #34
That was to much...I got to post a pic of my hot sauces that I collect......I have some pure capsaicin.
