Old 03-23-2009, 12:57 PM   #21
how hard is that to do? i mean obviously after you buy the parts... does everything fit nicely?
There's a slight amount of modifying, but nothing terrible. WOT-Tech sells most of what you'd need for that.
Old 03-23-2009, 11:46 PM   #22
99alerogirl
Female.
99alerogirl's Avatar
99alerogirl will become famous soon enough
what's having the pistons balanced? some of the pistons look to be rusting on top, correct me if i'm wrong and that's not possible. especially in cylinder 4... there was a lot of water in it, can't really see it well in the picture though.
2012 Hyundai Veloster - new 40 MPG DD!!
1990 Nissan 300ZX Twin Turbo 5 speed - "Zeus"
2005 Nissan Titan SE King Cab 4x4 - gas guzzler
99alerogirl is offline   Reply With Quote
Old 03-24-2009, 12:02 AM   #23
build for boost with new pistons......and get the entire assembly balanced.....
Old 03-24-2009, 12:02 AM   #24
99alerogirl
Female.
what does balanced mean?!?!?!
Old 03-24-2009, 12:06 AM   #25
means like, taking off material from the rods and crankshaft in places to make everything balanced as it spins
Old 03-24-2009, 12:08 AM   #26
99alerogirl
Female.
hmmmm ok.... hahahahhaa
Old 03-24-2009, 12:12 AM   #27
Bad99Olds
New and Improved
Bad99Olds's Avatar
Bad99Olds is on a distinguished road
Send a message via AIM to Bad99Olds
its like when your drunk and take off certain articles of clothing to make aerodynamics and balance more easily attained. atleast thats how u perceived it at the time.
Bad99Olds is offline   Reply With Quote
Old 03-24-2009, 12:17 AM   #28
99alerogirl
Female.
OH ok.
Old 03-24-2009, 12:17 AM   #29
WhiteV6
Wide Open Throttle
WhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond repute
That isn't balancing the pistons though. Balancing the rotating assembly is where you match each piston and rod to each other, and the crank to this weight. Anything that bolts to the crank can also be included to get the balance set.
This makes the engine run much smoother, which will help everything from durability to peak RPM potential, power output, and efficiency.
You should drain the coolant and spray the cylinders down with WD 40 after the water is removed. Rust in there is not good.
Ben
WOT-Tech.com
60DegreeV6.com
WhiteV6 is offline   Reply With Quote
Old 03-24-2009, 09:21 AM   #30
Crankshafts are balanced at the factory. I used to be an engineer at such a facility. (LS7 baby!).
Ok they are balanced, but there is a balance SPEC. The truth about balancing is theres nothing perfect. I can spin the same crankshaft up and have different readings every time...
Old 03-24-2009, 09:22 AM   #31
Bad99Olds
New and Improved
Bad99Olds's Avatar
i just got sexually excited thinking about the ls7. not as cool as the ls9 or lsa, but damn is it close.
Old 03-24-2009, 09:40 AM   #32
cliffordwoeller
You got beat by an Alero!
cliffordwoeller's Avatar
cliffordwoeller is on a distinguished road
Send a message via AIM to cliffordwoeller Send a message via MSN to cliffordwoeller Send a message via Yahoo to cliffordwoeller
OH ok.
I love how the examples you have to use for her to get the picture.lol
its all good I need good examples to understand things also, if you can relate it to xes then I will def get it then lol
cliffordwoeller is offline   Reply With Quote
Old 03-24-2009, 09:45 AM   #33
Bad99Olds
New and Improved
Bad99Olds's Avatar
haha yea, because you watch that much porn.
Old 03-24-2009, 09:48 AM   #34
Among the LS7 we also did the Viper, GT40 and Hummer cranks. The sister company specializes in cranks for drag racing, Callies High Performance.
We made a few different prototypes for GM closely related to the LS7. Most of them had a little les stroke- Im assuming for Turbo
Old 03-24-2009, 09:50 AM   #35
Bad99Olds
New and Improved
Bad99Olds's Avatar
mmmm, less stroke. that gives me a boner too. god im a walking erection this morning. this international relations exam apparently cant kill my sex drive.
Old 03-24-2009, 10:19 AM   #36
cliffordwoeller
lmao hey there is nothing wrong in my mind of a healthy dose of porn, sex,girls or anything else of the nature
Old 03-24-2009, 10:32 AM   #37
I was wrong. looks like they went supercharged...
http://smallblockscreensaver.com/images/X09PT_EP047.jpg
I dont follow these things...
Old 03-24-2009, 10:49 AM   #38
Bad99Olds
New and Improved
Bad99Olds's Avatar
its ok, forced induction is forced induction at the end of the day. lol. this is a predominant reason my next car is going to be the most recent gen of cts-v, becase that ls-a is just too effing sexy. corvette perormance with cadillac luxary? SOLD!
Old 03-24-2009, 11:54 AM   #39
i concur, i want a cts-v for my next project car something fierce....
hennessey cts-v
http://www.youtube.com/watch?v=vd5lx0PUkGY
Old 03-24-2009, 12:19 PM   #40
Bad99Olds
New and Improved
Bad99Olds's Avatar
i mean the lsa is a detuned ls9, so you wait till the zr1 guys get rid of their parts, or untill there is an aftermarket, and you can squeeze some crazy ponies out of that bad boy.
