Old 07-13-2010, 03:58 PM   #1
joshkrdr
joshkrdr is on a distinguished road
Hey cherrington, how many led's did you use in the HVAC? Did you just replace the existing lights or add more? Also, what degree range led's did you put in?
joshkrdr is offline   Reply With Quote
Old 01-09-2010, 05:34 PM   #2
glad my how to helped ya. (i knew that +/- pic would help)
I'll do doing some of these in my free time as well. As soon as I get my HVAC from cactus, I'm making a set for chipmunk with red. To see how it turns out...
ryan, what color did you do? got pics of the finished product?
Old 01-09-2010, 05:42 PM   #3
I used ultra bright 5mm whites for the 8.
I used 3 green ones for the replacements. Im not sure how bright the greens are. All were bought from rat shack.
The how to was good. Whats lacking in the pictures to know whats truly + and -. The one said "two pictures up" and I went 3. Even that was a bit fuzzy.
I would HIGHLY suggest to people letting someone with skill do this.
Old 01-09-2010, 06:12 PM   #4
I'll relook at the pics tonight... make sure they are labelled correctly...
and yes, if you have a really hot soldering iron, or hold it on the circuit board too long.. you will pull up traces... which is BAD
Old 01-09-2010, 07:22 PM   #5
This is what I got, with a .06 and .19 tips.
http://www.amazon.com/Weller-WLC100-.../dp/B000AS28UC
Using the proper solder, flux and wick is key. Have you tried Che-Wik yet? When you do, you wont bother with the other junk...
Best pic I could get.
I noticed some flicker... Im thinking when I did the gray wire my one solder joint wasnt the best...
Old 01-09-2010, 07:42 PM   #6
You'll want a 15 or 25 watt soldering gun. I used a 45, and it was WAY too hot.
luckily.. no traces were compromised.
Old 02-09-2010, 02:17 AM   #7
Just finished this mod, and damn blue hvac lights with the transparent knobs are sick as hell
Old 02-09-2010, 03:33 AM   #8
PappaSmurf
PappaSmurf's Avatar
PappaSmurf is on a distinguished road
Al, Cherry, or Ryan,
I am glad that you all have got this mod installed and working. Now I know that one of yall would be willing to do this for me and make some extra cash. I was just wondering which one of you could do it, send me the hvac unit and then wait for MY hvac unit to replace the one you gave me.
I only ask because I am not the best around a soldering gun, unless you want a glob of silver stuff covering the whole thing. LOL
-Smurf-
"Check mate Bitch!"
PappaSmurf is offline   Reply With Quote
Old 02-09-2010, 10:19 AM   #9
Aye smurf Text me
Old 02-09-2010, 08:47 PM   #10
just thought id thro up a pick with the blue knobs, i have to find the last one, i seem to have misplaced it
Old 02-09-2010, 10:59 PM   #11
Nice hein-y...looking sweet!
I have a red hvac on standby, for chipmunk. (Swapping hvacs in the winter is crazy) but ryan and hein-y have had good results, id trust either of them to do it properly. Its easier then it looks. (Espicially w. The idiot proof write up. )
Old 02-09-2010, 11:20 PM   #12
yea i went sorta LED crazy this weekend did the vents, hvac and floors
Old 03-30-2010, 09:53 PM   #13
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
hey guys my leds have a long stem and a short one, which is positive?
Old 03-30-2010, 10:10 PM   #14
Chris2000
Chris2000 is on a distinguished road
Apparently you have never heard of google or any other type of "search" engines.
long = +
short = -
Chris2000 is offline   Reply With Quote
Old 03-30-2010, 10:09 PM   #15
colonel6632
colonel6632's Avatar
long stems are normally positive. but not always. just hook it up to a battery and find out
Old 03-30-2010, 10:15 PM   #16
If he does that without a resistor it'll get really bright and then pop.
X2 @ the google it takes longer to log on here and post then to just google it
Old 03-30-2010, 11:30 PM   #17
colonel6632
i used a 1.5 volt battery. i didn't mean the car battery. guess i should of been more specific
Old 03-31-2010, 12:59 AM   #18
o ok i use 9 volts, and i tried that without a resistor and pop! one less LED
Old 03-31-2010, 08:56 AM   #19
yup.
button cell batteries, or a 2 pack of AA/AAAs work well as testers. OR (with resistors) a 12V power supply.
Old 03-31-2010, 12:02 PM   #20
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
i did google and went ahead and soldered, i wish i had somthing to test it off of, down side of soldering in your dorm room,
ive got to go back and resolder 3, i had one place where the copper lead came up, but not form the heat, from putting the led through so i soldered the copper part to the led very carefully, itll be interesting if that works, if not its a negative and i think i can coppy what ryan did and make it work
