Old 03-05-2010, 09:44 AM   #21
AGT
AGT's Avatar
Yep. I have not had issue or drip since I let the air out
Have a good day
Old 03-10-2010, 06:54 AM   #22
2004alero
2004alero is on a distinguished road
i am having the same issue but i have changed my thermostat 3 times bleed the system flushed coolant had a mechanic check all the lines and my radiator also water pump also i when it over heaters all the presser pushes all my coolant out the overflow so i must have spent 300 this month on coolant. and another issue i been having is misfire cylinder 2 i replace spark plugs wires coil pack thought is was clogged fuel injectors but Ive used injector cleaner for 2 months every fillip. any suggestions would be great.
2004alero is offline   Reply With Quote
Old 03-10-2010, 12:48 PM   #23
sfi3400
sfi3400's Avatar
sfi3400 is an unknown quantity at this point
Send a message via AIM to sfi3400 Send a message via Yahoo to sfi3400
when that happened to me they said i needed a radiator flush, and it worked great heat came out to hot lol
sfi3400 is offline   Reply With Quote
Old 03-10-2010, 01:12 PM   #24
headgaskets, same issue i had
Old 03-10-2010, 11:27 PM   #25
TxAlero
TxAlero's Avatar
TxAlero is on a distinguished road
oh what nate said ..headgaskets or even worse a cracked block. Go to a shop and pay 40 bucks to do a sealent check on your coolent system. After that you should know.
TxAlero is offline   Reply With Quote
