Old 09-10-2010, 06:30 PM   #21
Lucalare
Originally Posted by tunerkid View Post
if you drove this GTO it's not a nice smooth ride and then idles down nice and easy to. you let off the throttle it slows down fast(with aftermarket flywheel, stock ones are heavier and give a little more momentum.) but anyways i havn't got the gearing right for regular driving.
If it's not smooth skipping a gear would be even rougher, may even cause a tire skid. Plus those old engines won't take high RPMs like some of the newer ones will, so why push it?
1987 Honda Rebel 450
Old 09-10-2010, 07:06 PM   #22
tunerkid
tunerkid tunerkid tunerkid tunerkid tunerkid tunerkid tunerkid tunerkid tunerkid tunerkid tunerkid
tires almost always skid in downshift on that car.
yaa they don't but the 455 def takes more rpms's than the 400 but i don't even dare take it over 4,000 rpms
tunerkid is offline   Reply With Quote
Old 09-11-2010, 12:48 AM   #23
guiguilandry
guiguilandry's Avatar
You do have it ?? If so I'm sorry I said that joking...
Replace the fork is a pretty complex process it invloves drain the oil, removing the tranny, disassenbling it, check all the clearances and specs with appropriate tools and then find the parts and replace them, reassemble the tranny and cross your finger so that the rest will hold.... Your best bet is to get a good used tranny from a salvage yard.. Like tha tyou do not need to dissasemble it or nothing.
But while doing this you should be better check the condition of your clutch and replace it if needed, at the same time you'll have to put new tranny fluid in, I strongly suggest to use Gm synchromesh fluid.
Originally Posted by Devinbajus View Post
I do have the Parkinson. I have only had the car for a month and a half now so I don't know how the car was driven before that. Also I just noticed unless your stopped first and second are a little stiff getting into gear. So what am I looking at for cost of a tranny. Is it difficult to replace. I will check the fluids once I get a chance to do so. How difficult is it to replace the forks or get them fixed. I'm new to this car and haven't done any work to it yet.
Custom or Nothing...
www.demonautosport.ca
Old 09-11-2010, 10:41 PM   #24
Devinbajus
Devinbajus is on a distinguished road
Originally Posted by guiguilandry View Post
how can you hit the reverse while driving do you have parkinson ?
i thought you meant the reverse thing just how you put it. i dont have parkinsons disease. sorry long days at work really mess me up
Devinbajus is offline   Reply With Quote
Old 09-12-2010, 12:04 AM   #25
lmfao, that was pretty epic.
I've never dropped the trans on an Alero before, I assume the subframe's gotta drop, then mounts/bellhousing bolts and it'll drop out?
Old 09-12-2010, 12:21 AM   #26
alero_bmxer
alero_bmxer's Avatar
if i remember correctly, when i had my trans rebuilt (2.4) the tech took the left side cradle bolts completely out, then dropped the right side cradle bolts as far as they would drop without completely coming out, then unbolted the motor mounts, suspended the motor from up top and somehow finagled the trans out
Old 09-12-2010, 12:42 AM   #27
colonel6632
colonel6632's Avatar
that probably works, i also have good luck with mobil1 full synthetic tranny oil
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
