Prev Previous Post   Next Post Next
Old 03-26-2011, 05:59 PM   #1
myowneq
myowneq is an unknown quantity at this point
Air Conditioner Problem
Hello Everyone,
I was minutes away from selling my car when the buyer noticed that while the AC said it was on, it wasn't blowing cold. Couldn't tell in the shade, but in the sun, noticed it right away.
So I've been working on it and here's what I have. It's an issue with the relay. The relay is good. I've verified that by swapping it with a known good one and putting it in something else's slot. The compressor is good. I can manually start it by using a jumper wire in the slots. Blows cold when you do that.
However, it's as if the relay is not get the power that tells it to turn on. According to the page from my Haynes manual, the green white wire runs from the computer under the dash to the relay in the fuse box under the hood. There were four, but using the continuity beeper function on my multimeter, I found the right wire. A voltage check at the coming out of the computer gives me 12v, but at the fuse box, there's nothing.
Any ideas?
Thanks,
Timothy
myowneq is offline   Reply With Quote
