Old 05-28-2011, 12:00 PM   #21
Originally Posted by widbyj View Post
FYI - The PROPER bolt pattern for the GM platform IS 115x5. Might as well do it right. Also, hub centering and support IS important. just sayin...
You really think 0.3 millimeters of diameter difference is going to matter? 5x114.3 and 5x115 are completely interchangeable without worry. Motorsport-Tech already knows it's 5x115 and that's what the spacer is made to. The lugs they put on them are going to be 5x100 because that's the other bolt pattern the wheel accepts.
Also, my wheels right now have a center bore bigger than the Alero's hub size. No hub-centric rings, and I've had them on since '08 without issue.
Old 05-28-2011, 12:55 PM   #22
It can make a difference, depends on the particular setup. I tried a 114.3 wheel in a 16X8 size, correct hubcentric rings and all, never could get them to run right. Finally returned them to the local performance tire shop, who were good at their job, btw. Sold them back minus a wear charge.
Old 05-29-2011, 12:21 AM   #23
mrmike
mrmike's Avatar
mrmike is an unknown quantity at this point
since I have motorsport-tech spacers i should share a few measurements i found when selecting them.
difference of (front wheel to fender) to (rear wheel to fender) is 20mm
stock gls wheels 16x6.5 +42mm offset distance to fender F 30mm R 50mm
Basically this means that you need 20mm extra in the back to make the wheels an equal distance to your fenders. Ideally a new set of rims should stick out 30mm wider than the stock 2000+ gls wheels to get them flush vertically as well. One other thing I would recommend with this setup is a wider tire up front, maybe 245 or 255 on a good set of 8" or wider rims. The alero has different fender angles front to back, so this setup makes the rear wheels appear farther out than the fronts. A nice beefy sidewall up front will fill up the difference in appearance. I'm not the best judge of performance, but I know that I have less bodyroll and more sensitive steering when I have the wider wheels on. I run stock through winter so I have plenty of time driving both setups. Also, you would need maybe 40mm-45mm spacers to clear the studs. I can't use the spacers with my stock wheels because of this. One final note is don't underestimate the importance of offset. Some wheel websites don't even list the offset, but it is the most important measurement in achieving a great looking stance. For more info on tire width/offset and a great offset calculator, check out http://www.1010tires.com/tech.asp
mrmike is offline   Reply With Quote
Old 05-29-2011, 01:31 PM   #24
Old 05-29-2011, 05:02 PM   #25
Hahahaha, I realized it when I re-read it, but AleroB888 quoted it so editing it to 0.7 wouldn't matter. I was thinking 0.03" because 5x115 is 4.53" and 5x114.3 is 4.5" lol too many numbers/units switching back and forth
Old 05-30-2011, 12:44 PM   #26
Just ordered 27mm (1.06") ones. Can't wait. I hate how it looks right now as the body kit makes it look like the wheels are tucked in too far. This should make it look much, much nicer.
Old 05-30-2011, 08:42 PM   #27
too bad you can't just buy the right wheels.....
Old 05-30-2011, 08:45 PM   #28
Send me money and I'll go buy a whole new set of wheels.
Old 12-29-2011, 09:11 PM   #29
jhubbz
⌘ Irish Pride
jhubbz's Avatar
Just put a set of 1.25" adapters on the rears. Definitely gives a wider-looking stance, altho I may have been happier with 1". Will get a pic in the daytime here soon. I unfortunately did not get the hubcentric adapters, but I took my time and lined them up well, so hopefully they will be fine in the future. I did apply some threadlock to the stock studs for extra assurance
Done lost my mind
Old 01-08-2012, 07:00 PM   #30
jhubbz
⌘ Irish Pride
jhubbz's Avatar
The spacer:
Before:
After:
Overall, I'm happy with it. I will definitely invest in some hub-centric ones once I am able to lower it.
Done lost my mind
Old 01-08-2012, 07:44 PM   #31
mrmike
mrmike's Avatar
It looks good and all, but I would be scared to drive it. Hubcentric wheels are supposed to have the hub support the weight. Without the hub center there, the studs are taking both the vertical and rotational load, as well as the added handicap of not even being bolted through the hub. Even on my hubcentric ones, the wheel can rotate relative to the spacer, so I need to constantly retorque them.
Old 01-08-2012, 08:13 PM   #32
spc2125
spc2125's Avatar
man i just love how clean jhubbz ho is
just call me "Doc"
Check out my alero!
Aleromod Showcase Video
Old 01-09-2012, 12:48 AM   #33
The look is great but I prefer to do it the right way with the right offset, wider rims, and wider tires....
Old 01-09-2012, 02:25 AM   #34
mrmike
mrmike's Avatar
^ Do you have a staggered set of rims? Pics please.
Old 01-09-2012, 09:02 AM   #35
I know, its quite beautiful. I need to give mine a good wash and wax.
Old 01-09-2012, 11:07 AM   #36
No I don't. I have a correct set of rims for the front that fit perfectly. The rear sit in. I don't think staggered rims belong on a FWD vehicle. Make the front flush and let the rears sit in. If you make a bigger rim on the rear you are just adding more weight which is unnecessary. I actually run a smaller tire in the rear than in the front.
Old 01-09-2012, 12:46 PM   #37
jhubbz
⌘ Irish Pride
jhubbz's Avatar
Thanks guys for the compliments. And yea I agree it is kinda scary not having them hubcentric. I will get some decent ones soon. Maybe not til summer tho
Done lost my mind
