Old 06-17-2011, 07:33 PM   #21
Originally Posted by JLw7123 View Post
well the engine is off so there are no noises to make.
I think he's talking about the shift plus is on the engine makes a noise, and when the shift plus is off there is no noise.
Old 06-17-2011, 07:50 PM   #22
the_weber
the_weber is on a distinguished road
'00 Alero GL - 11X,XXX miles
-4500K/6000k/30000k(purple) HID's Hi/Lo/Fogs
-Carbon fiber pillars, door handles, and Gas cover
-Optima yellow top. This battery went end over end in my jeep (not strapped down) 13 times for 75 feet. and now is in my alero. one tough battery
-Cleared Corners/Painted Bezels
the_weber is offline   Reply With Quote
Old 06-17-2011, 07:55 PM   #23
well what kind of noise does it make when it is plugged in.
Old 06-17-2011, 08:02 PM   #24
the_weber
lol no offesne but it had to be done
almost like a grinding noise, soft though, not like screeching or nothing
Old 06-17-2011, 08:04 PM   #25
does it happen when it up shifts or down shifts or both. also i am thinking that it might be ur tranny making the noise.
Old 06-17-2011, 08:07 PM   #26
the_weber
maybe it is the tranny, it happens in idle, I dont know if it happens while I am actually moving because i don't hear it.
Old 06-18-2011, 12:17 AM   #27
if your trans was slipping badly then its usually bad to increase the line pressure (what shiftplus does) because it puts extra strain on trans parts and often smokes it faster..the grinding is probably your transmission on its way out.
NOT SAYING THIS IS 100% TRUE!
Old 06-18-2011, 12:44 AM   #28
Philbar71
Its the transmission pump, When my tranny went in to limp mode temporarily (wouldn't shift out of second, and shifted with max line pressure) it made a whining/grinding noise.
Old 06-18-2011, 01:08 AM   #29
the_weber
it only slips at high RPMs like 6500. and it only happens when the shift plus is on. you sure that would be the pump?
Old 06-18-2011, 01:13 AM   #30
No doubt the shift kit added 3 seconds to your to your 0-60 time. Sounds more like the "butt-dyno" (no big deal, we all felt that way when we were just starting out in the modding area) but I also have no doubt the kit did not help you out a little bit.
Shifting harder will cause less wear to the clutches, so althought they feel like you might be hurting something, you're actually not.
Old 06-18-2011, 01:19 AM   #31
Philbar71
I was talking about the noise at idle. Im not sure about the slipping at redline?
Old 06-18-2011, 01:30 AM   #32
the_weber
Well it only makes that noise at idle. and red dog we timed it again and again. Now that it shifts when its supposed to its much quicker. acceleration hasnt changed or anything just now it doesnt redline
Old 06-18-2011, 12:48 PM   #33
alero_bmxer
alero_bmxer's Avatar
mine makes a noise too. im assuming there is a pump inside the trans and its spinning faster for increased pressure? (i could be totally wrong im no where near a trans expert)
Old 06-19-2011, 10:30 PM   #34
the_weber
so it might be just nothing then?
Old 06-20-2011, 10:32 AM   #35
widbyj
widbyj's Avatar
I would suspect the fluid pump inside the trans also. Mine has started to make more noise, similar to a Ford power steering pump, also in the last few months. The noises started to be noticeable about the same time as I was finally able to get the engine to run properly in closed-loop mode, it probably started to actually use the ECM tuning rather than the defaults (harder/faster shifts). There are also some internal parts in these trannies that GM upgraded from plastic to aluminum over the years, service notes indicate that the plastic pistons would crack and leak fluid (noises) while still functioning fairly well. Newer trannies already have the better parts installed so if you are going to swap one through a junkyard try to find the most recent one they have... I suggest checking/changing the fluid and filter to get an idea of whether any real damage is happening. Adding a trans cooler and gauges to monitor heat and pressure might help you keep it happy longer also. Oh, stay away from the redline also, power peaks well below that point.
Old 06-20-2011, 01:50 PM   #36
Oldsman
Owner
Oldsman's Avatar
the noise IS the pump!!!!!!!!!!!!!!!!!!!!!!!
no worries, drive and enjoy
Beware of the BackStabber
Old 06-21-2011, 01:40 AM   #37
Philbar71
Since you put it that way... I just orderd mine! Should be here thursday or friday along with springs
