Old 10-13-2011, 07:27 PM   #21
SIUlero
SIUlero's Avatar
SIUlero is on a distinguished road
He never said it was overheating:
Originally Posted by Papa Rad17 View Post
I dont like it when it goes to or above the half mark on hot days... iv been told its perfectly fine, but still...
The halfway mark is the ideal place for it to run...going a little past that on hot days (especially with the A/C running) is to be expected. It sounds like your cooling system is running optimally. If stock is 180, I wouldn't recommend going any lower, especially with cooler weather coming on...your heater won't get as hot and it could lead to gumming up your oil, as lower temps won't boil out condensed water vapor from your crankcase as easily (same reason cars that are only driven short trips where they don't fully warm up get gummed up). Fuel mileage will likely suffer also.
SIUlero
'01 Alero GL
'72 Cutlass Supreme
http://www.cardomain.com/id/CrazyOldsGuy
SIUlero is offline   Reply With Quote
Old 10-13-2011, 07:28 PM   #22
Yeah your cooling system is normal.
Our radiators are tiny. If you want it to always stay below 1/2, get a bar and plate aluminum thick radiator.
