06-04-2012, 11:42 PM
#21
Sweet! I would spray them with high temp header paint and Header wrap them. but if there is thay little clearence already i may not be able to wrap em.
You do not want to wrap the headers at all. The heat wrap will help keep temps down but will cause the headers to wear out really fast. The money you will spend and the time to wrap them you can have them ceramic coated.
2002 Grand Am GT Turbocharged
Garrett GT35 / Turbo Headers / 2.5" high flow DP / 60lb Injectors / Custom SLP Exhaust / Ported 3500 Heads / Ported 3500 UIM/LIM / 65mm TB / Turbonetics Evolution WG / Greddy Type-RS BOV / Casper Adjustable FPR / Casper High Speed Fan Switch / Speedbuilt F/R STB's / Next Level F/R Sway bars / Eibach Springs / Dual Gauge Pod with Aeroforce Gauges / Big Four Upgrade / HP Tuners and more!
"Living is doing everything you want to do and dying is everything else"
06-05-2012, 12:20 AM
#22
I don't think S&S makes headers for our cars anymore. I love mine though.....over 70k on them and no problems.
06-05-2012, 12:38 AM
#23
Wrapping looks better and its much cheaper!
06-05-2012, 12:58 AM
#24
Yeah but looking better is not worth the fact that the wrap will break down the metal faster then leaving them bare, painting them, or best yet coating them. I looked into wrapping my headers and what I found was to stay far away from using it on headers because it just isn't worth it in the long run.
06-05-2012, 08:19 AM
#25
I dont see how geting them coated makes them any cooler than wrapping though
06-05-2012, 09:16 AM
#26
wrapping doesn't make them cooler, it actually makes them hotter but it contains that heat and moisture inside the wrap making your engine bay cooler. in turn after the header is exposed to so much heat it starts to rust and become brittle, after a while if you try to unwrap your headers they will literally fall apart.
coating helps them retain more heat inside the pipe, your underhood temps won't be as cool as with wrapping. but it's still better than bare metal or paint, and it prevents rust.
06-05-2012, 11:16 AM
#27
Soo im coating than wrapping i guess
06-05-2012, 11:30 AM
#28
No don't wrap them! Coating is all you need. I cant stress to you enough how bad wrapping headers is. Here these guys are the best in the business for coating. http://www.jet-hot.com/
06-05-2012, 11:37 AM
#29
Lol!
06-05-2012, 09:56 PM
#30
Originally Posted by Mike The Canadian
Your stock one?
The OBX one is a resonator..
I don't suppose it matters if yo uhave a smaller CAT, you do lose some of the flow though.
Scott cut the ends of my stock CAT out to 2.5 and I had it welded in place of the resonator on the new downpipe.
I meant the OBX CAT. I just wondered if it hurt performance at all, but it sounds like having a shorter CAT does.
06-05-2012, 10:01 PM
#31
Lol!
couldn't you just make a bracket to push the pipe away 1/4 on an inch or just make a shim to place in between the header and engine body? Probably sounds stupid but whatever.
Yes I realize I quoted you lol, I thought it would add to the humor ![It's Hammer time](images/smilies/MC Hammer.gif)
06-05-2012, 10:19 PM
#32
Baahahaha where did that mc hammer thing come from wtf lol
06-05-2012, 10:44 PM
#33
Ahh... if anything the OBX rendition of a CAT was just as big in diameter and much more free flowing than a CAT!
06-06-2012, 01:00 AM
#34
And it kind of looks like a cat so the cops wouldnt know any better
06-06-2012, 01:24 AM
#35
What cop is going to crawl under the car and check if you have a cat? ![:LOL:](images/smilies/lol.gif) That's one dedicated/car savvy cop!
06-06-2012, 01:31 AM
#36
But does it smell like a cat??
06-06-2012, 05:50 AM
#37
Nope, it stinks like muscle car.
It used to drive me nuts ![:LOL:](images/smilies/lol.gif)
06-06-2012, 05:30 PM
#38
I spoke to the powdercoating shop I deal with here and they fix a lot of Jet-Hott's problems.
If your already going to send the headers to Jett Hott which is in King Of Prussia, PA, might was well send them another 30 miles to Bonehead in Warminster, PA.
They won't be shiny, but the color will last and not discolor ![Wink](images/smilies/smilies/wink.gif)
06-07-2012, 05:47 PM
#39
Bonehead does really nice work too. I just talked to them about my sway bars and lateral arms I would go with them !!! I had them do some parts for a 42 Chevy truck last year. Fast turn around. And good guys to deal with.
