Old 01-14-2013, 01:04 AM   #21
MilzyZ34
MilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond repute
Send a message via AIM to MilzyZ34
by the way, it is much easier to get the pin seated in the pcm connector if you remove the transparent cover on the pcm connector first. They you can easily feed the pin in until it clicks.
www.milzymotorsports.com
MilzyZ34 is offline   Reply With Quote
Old 01-14-2013, 04:10 PM   #22
happyisthealero
happyisthealero is an unknown quantity at this point
I will keep that in mind when I make another purchase on your website, do you still FPR's?
happyisthealero is offline   Reply With Quote
Old 01-14-2013, 07:59 PM   #23
MilzyZ34
I can sell the TCE fpr, but honestly you don't need it unless you go boost, and even then the stock one can still work fine. I can also sell you a Aeromotive fpr if you want to. I think those are around $140 or so. You have to make your own lines for that one, but it's a nice regulator.
