Prev Previous Post   Next Post Next
Old 05-21-2013, 02:40 PM   #1
TaurineMike
TaurineMike's Avatar
TaurineMike is on a distinguished road
Stero Question
Hey guys,
So the 23rd is my brother's 18th birthday, he previously had a deck put in a few years ago. He acquired a new radio for his car and recruited the help of his friend who essentially wrecked his deck and left him high and dry. He owns a 2001 Grand Am GT, non-monsoon. I have appropriately matched the aftermarket wire diagram to match his factory wire diagram.
Attached I have some pictures/information in this post that perhaps can help you guys find the problem.I have always hard-wired my systems however I am having a little trouble running power to the radio itself.
The radio does work when constant power is applied through a straight-wire from fuse-box. I matched put both his accessory (Red) aftermarket with his aftermarket 12v constant (Yellow) with the straight wire from fuse-box. This causes the radio to stay on even after ignition\car is off. The way I understood to do it is to match the (Orange) factory constant to the (Yellow) aftermarket constant. Than I was to match the (Red) aftermarket to the fusebox to provide memory and also to tell the radio when to turn off.
Does anyone have a solution? I have tried everything with the wires. The only thing I can figure is that his (Orange) Factory wire for 12v constant doesn't work properly.
Factory:
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: Mounted behind trim in the left side of the trunk.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Aftermarket:
http://imgur.com/a/ujgdO
I hope you guys have some answers. I've ran out of options .
Mods include: Hood scoop, Black pin stripping, cool air intake, sound system(6 1/2 front 6by9 back pioneer), 1200w amp with 12dp switch, big three upgrade.
Mods in the making: 65mm Throttle body, B&M Shift Kit, Spyder3 hood scoop, HP Tuner??, Pacesetter Header, Magnaflow High Flow cat, and Catback Exhaust System
Unfortunately there is no misplacement for displacement.
TaurineMike is offline   Reply With Quote
