Old 01-28-2015, 02:34 PM   #1
While I don't know for certain, the fogs are powered by the low beam circuit from the switch, so they should stay on.
Old 01-29-2015, 01:09 AM   #2
Im not sure of that, sounds solid. but if not it shouldnt hard to rig. I do not have them and when I put some on will not be a factory install.
If it does not work for them, all you will need to do is find the ground wire for them and tie it right in there. That will leave it with a path, just like for the lows, when you flip on the high beams, and still have normal operation of them.
