Old 07-16-2009, 09:26 AM   #41
draginwagin
draginwagin is on a distinguished road
So when the lights go on (SVS, SBS, trac off), how do you know which wheel is the cause? Money is kinda tight right now with the wife gettin' canned. (Economy, budget cuts yada yada.) If I get it scanned, will there be a code, and will the code be wheel specific?
The lights 1st came on in a car wash, so I was hoping it was just a wiring problem that got wet. I figured it would go away after it dried out but no. I already checked the wires/connectors at each wheel and they look fine. There are no bearing noises so I'm guessing a sensor went south.
'95 Caprice wagon, some bolt on mods.
Weekend toy - 1980 Dodge Mirada, LA360, bored .040", Kieth Black pistons, 501/280 cam, milled/ported/polished, Holley 650, 10.5:1 comp., Dynomax headers, Flowmasters, SEO sway bars, HD rear leaf springs, 3.55 posi, SEO rims/dog dish hubcaps, ~400-450HP guess, never dynoed (for sale)
wife's car - '02 Alero, 3400 4dr, all stock.
draginwagin is offline   Reply With Quote
Old 07-16-2009, 10:06 AM   #42
Is it making any noise yet? Like a rumble or a grow that stops when you turn a certain way?
If not you still have some time?
If so, its usually the side that stops growling when you turn in its direction.
Old 07-16-2009, 10:29 AM   #43
Yea. It doesn't count as a wheel bearing problem until it growls.
Old 07-16-2009, 11:14 AM   #44
draginwagin
Shortly after startup, within the 1st 5 minutes of a trip it will make a funny noise as if the traction control is activating, then the lights come on and the noise goes away.
I tried to get it scanned at Autozone but no codes showed up and the guy said his code reader could only check engine codes but no body/chassis codes.
So I still don't know which wheel hub sensor is bad.
Old 07-16-2009, 12:25 PM   #45
I found alittle info on trouble shooting too.
http://www.paulstravelpictures.com/G...hts/index.html
