04-28-2009, 12:32 AM
#41
Ken, funny thing is I didn't pay any attention to this until Saturday AM and decided to click on the thread. Very interesting writeup on this. I know Cliff did this to his car and really didn't worry about it much because I only had the Final 500 at the time. Now that we have a 2nd Alero I am very interested in doing this project. I spoke to Cliff while at Scots house on Saturday and it seems very doable.
My question is where did you find it and how much for the unit?
04-28-2009, 12:59 AM
#42
Originally Posted by Redog
I understand the touchscreen FTW, but after about a year, they look like crap from being touched so much
My TNR still looks fine. You can only really see the touched spots when it's off. and they clean right off.
I will say that the INR will probably fit the bezel a little better. On mine a small portion of the screen goes under the bezel.
Originally Posted by lonnie
That was the next thing I was going to ask.....How much does it cost to get it programmed? I read something that they have to program it for your vin number. I got to say this is the best mod yet for audio in these cars.
They don't program the VIN to it, it's more like the Tech2 clears the old VIN information from it so that it will acquire the VIN from the car on the next power cycle.
And I bet the Pioneer one doesn't say "Oldsmobile" when you start the car
I heard around $60 but I have yet to call around and ask. IDK if the radio has to be hooked up or if you can just take the radio to a dealership and have it done out of the car. That is the way I would like it done.
The only problem is that the buttons light up white, not blue. There is a radio that lights up blue, but the part numbers are always the same. I gotta see if I can fix the blue lights issue
Some of the aftermarket ones can display custom images, but they still don't look original like this does.
Your problem is going to be getting the dealer technicians to put in the incorrect information into the Tech2 to get them to clear it. They usually don't like modified things.
The radio has to be powered up in order to clear it. Most places don't have a bench-testing setup to clear the radios so it would have to be installed in the car.
I wasn't aware of any of the INRs with blue buttons, but it would be cool if there were.
Originally Posted by AleroRacing
how much did that unit cost and do you have to pay for gps service or is it just a one time deal to get it programmed?
It works like any other GPS setup. All of the map data is on a DVD inserted into the unit. And before someone asks.... No, it can't play movies.
04-28-2009, 07:47 AM
#43
The Aleromod PITA
is the map data downloaded into the units memory or must the cd be in while navigating each time, sry the gps i use for trips is a portable dashtop unit
04-28-2009, 08:47 AM
#44
You know I thought that thing played DVD's too....well I don't want it now but it is still cool!
04-28-2009, 09:08 AM
#45
The newer ones play DVD's, but I don't think they will work in the Alero.
1999-2000 models require a "re-pin" newer Aleros are plug and play. Cliff can you verify ![Wink](images/smilies/smilies/wink.gif)
04-28-2009, 09:37 AM
#46
Are there any video inputs on it, to maybe hook an after market dvd player up? When you say repin you are talking about just rewiring the harness correct?
04-28-2009, 12:50 PM
#47
The DVD is in the drive the whole time. So that rules it out as an audio source while using it. You can however add on a CD changer, XM Radio, etc...
Only the map DVD. There is no MPEG decoder built into it.
You might be able to modify some other ones that play DVDs to go in the Alero (like the one in the Corvette, GP or older Cadillac).
The only thing you have do do to install it into a newer Alero is add the VSS wire to make the GPS movement smoother. It's not even 100% necessary, just makes it nicer and is the proper way for it to be installed.
There are aftermarket solutions for both the INR and TNR models to add a video input which would work like this. I actually have one, but not for that purpose. I'm going to add a back-up camera eventually.
05-06-2009, 11:00 AM
#48
Well here's the update:
I can't find a place that can successfully unlock the radio. I know it can be done.
I took it to 2 GM dealerships and a aftermarket radio place that one of the dealerships called and they all said the same thing, "It can't be done"
I just read instructions on the Chevy SSR Fourm (and they used the same radio) and I doubt they are using the same set of directions that I saw here.
The problem is, I cannot get my hands on a GM Tech II tool. It's a $4500 unit and stores like Pep Boys don't loan them out, let alone have them. I asked my wife if her school has one that I could use, on their grounds of course, but she doubts it too.
I could call a few more dealerships but I'm starting to lose hope here. Like I said I know it can be done.
If I sell the unit, I will also be selling the Nav Antenna. I have a price in mind. I will not sell for less than that. It's exactly what I paid for it. ![Wink](images/smilies/smilies/wink.gif)
05-06-2009, 11:11 AM
#49
gotta love when mechanics must know more then you, and therefore, will NOT listen to you when you tell them something that they didn't know was possible.
05-06-2009, 12:29 PM
#50
good luck selling it on here after you just told people what a hard time your having unlocking it....it can be done so im sure someone would snatch it
![](image.php?u=3572&type=sigpic&dateline=1269488373)
05-06-2009, 01:36 PM
#51
Ken, Just send it to me and I'll get it unlocked and send it back. The thing is, you have to try and be there when the technician is there doing it so you can direct him how it's done. Fortunately I know a place that has a Tech 2.
#52
Really all someone has to do is call around... if you find a place that can do it, then buy it from him.
05-06-2009, 05:16 PM
#53
Really you can do that for me?!?!?
I have your address but can't make out the street name
05-06-2009, 05:50 PM
#54
New and Improved
wow you are one lucky son of a bitch... lol
05-06-2009, 06:47 PM
#55
^^ For real.
I'm super grateful for this.
I'll send Cliff the money also to ship it back. It's only $15 with all the extra insurance ![Wink](images/smilies/smilies/wink.gif)
05-14-2009, 04:41 PM
#56
I want to see pics when you finally have it installed in your dash.
I'm also curious as to what the factory service manual was about all this TheftLock stuff.
05-14-2009, 05:22 PM
#57
There is a How-to thread about it and there are pics of it in there.
I just got an iPod interface and will be hooking that up along with the Nav unit when I get it back. The interface requires a littie bit of modifaction to have the GPS work correctly (VSS wire) but I'll show that in the How to. I'm going to close the old one and re-write it
