Old 03-09-2015, 08:04 PM   #41
New clutch and pressure plate came today.
Shitty part was GM doesnt have a clutch alignment tool that comes with the set, any auto store you get a clutch from, gets you a clutch, pressure plate, and tool to align it.... So after work i went to 3 different auto stores, none of them could help me unless i bought a clutch. Lol so i had to find a 23 spline for GM vehicles on ebay, paid 7$ plus 5 extra for faster shipping because im trying to work on the car this weekend.
Old 03-10-2015, 08:03 AM   #42
03Alerosil
03Alerosil's Avatar
Good looking clutch. If you are junking your other F40 you could use the input shaft from it. They make great alignment tools.
Old 03-10-2015, 11:41 AM   #43
No, i ordered a tool. 12$
The other f40 may be kept as a back up/rebuild so if anything happens again, i could have a transmission on hand to swap back in. But im not sure yet.
Old 03-10-2015, 04:25 PM   #44
03Alerosil
03Alerosil's Avatar
You could put all new synchro assemblies in it and bearings and have another good transmission.
Old 03-10-2015, 06:13 PM   #45
Yeah just gotta find a place to do it.
Gm said they dont rebuild the f40, they just replace them with a new unit.
Old 03-10-2015, 06:20 PM   #46
03Alerosil
03Alerosil's Avatar
It's probably gonna have to be done by a specialty shop that only does transmissions. Or you could tackle it yourself. They are not overly hard
Old 03-10-2015, 07:34 PM   #47
I will never rebuild a trans. Ill pass! But yeah i will find a shop eventually to do that.
Old 03-10-2015, 10:33 PM   #48
Babyblue
Babyblue's Avatar
Babyblue is on a distinguished road
I just can't wait till sleepy and I are lined up!! Great job buddy!
Babyblue is offline   Reply With Quote
Old 03-11-2015, 08:36 AM   #49
Well its official, no one around me can or knows anyone that can resurface a dual mass flywheel....
New from GM has a price tag of 587$ + tax.
Ill find out this weekend if i need a good resurface, if i do, ill have to just buy a new flywheel unfortunately.... Fingers crossed its not bad.
Old 03-11-2015, 07:02 PM   #50
03Alerosil
03Alerosil's Avatar
Can you just install a regular flywheel? All a dual mass does it soak up torsional vibrations so your shifts feel smoother
Old 03-11-2015, 08:29 PM   #51
Idk i think you need to use the dual mass...
Today after work i pulled the old transmission off along with clutch and everything.
Flywheel is pretty bad.
Old 03-11-2015, 09:40 PM   #52
03Alerosil
03Alerosil's Avatar
Flywheel is shot. You do not need to use a dual mass. It's a popular swap in F-350 to dispose of the dual mass and put in a solid one. All a dual mass does is fall apart and soak up some shifting action. I would look up a solid flywheel
Old 03-11-2015, 09:59 PM   #53
Ill have to talk to milzy about that to be sure... Idk if i can do that or not.
Old 03-11-2015, 10:05 PM   #54
03Alerosil
03Alerosil's Avatar
Let us know but I believe you can.
Old 03-11-2015, 10:08 PM   #55
Im reading up on it now, some transmissions require a DMF, and coverting to a solid (single mass) flywheel, could result in added engine/trans damage because of the added vibration, since a DMF dampens vibration a bit more...
Old 03-12-2015, 12:25 PM   #56
Im just gonna order a new flywheel tomorrow, found a new one off gmpartsdirect for 314$, thats 200$ cheaper then the dealer. So ill just do that.
Old 03-12-2015, 06:38 PM   #57
03Alerosil
03Alerosil's Avatar
That's cool. You should shift good now
Old 03-12-2015, 08:18 PM   #58
On yeah,
Did some math tonight, so far i have spent 2,970$ while the car has been down, still have about another 1500$ to go...
Old 03-12-2015, 08:49 PM   #59
01GrandAm
01GrandAm is on a distinguished road
Just a heads up gmpartsdirect takes forever to ship, at least from my prior experience.
01GrandAm is offline   Reply With Quote
Old 03-12-2015, 09:07 PM   #60
Yeah, hopefully they are somewhat quick
