Old 05-04-2009, 10:29 PM   #141
I'ma make a how to soon as my shit's done.
Old 05-04-2009, 10:51 PM   #142
worknprog.99
worknprog.99's Avatar
that would be amazing... what does you cooler look like? i was thinkin about getting one with the inlet and outlets on the same side
Old 05-05-2009, 09:46 AM   #143
Spilner521
Boost Guru
Spilner521's Avatar
Originally Posted by worknprog.99 View Post
for those who have mounted an intercooler im getting rid of the free one i was given and buying one with the demensions of like 22x5.5x3 .. my question is how did you mount it? did you have to cut alot of the plastic off behind the bumper? because i had the bumper off today and that is the only way i see to do it.... any insight?
On my car, I mounted the intercooler to the metal crash beam behind the plastic bumper support. My intercooler is 31" wide and I had to trim the plastic bumper support a little just around the corners of the intercooler to fit it. With an intercooler that's 22" wide, you may not have to do any trimming at all.
I don't think I have a picture with the support installed, but here's the intercooler mounted to the crash beam.
Old 05-05-2009, 01:28 PM   #144
worknprog.99
thanks that helped alot....
Old 05-05-2009, 01:30 PM   #145
worknprog.99
eff
as we all know gm is effed and on monday they will be releasing the list of dealerships in ohio to close over 4200 nation wide.... we are a very likey candidate since there are two other gm dealers around us .... so should i keep going on the turbo setup or hold off and ride this through??
Old 05-05-2009, 01:31 PM   #146
Bad99Olds
New and Improved
Bad99Olds's Avatar
Bad99Olds is on a distinguished road
Send a message via AIM to Bad99Olds
Keep going.
Bad99Olds is offline   Reply With Quote
Old 05-05-2009, 08:51 PM   #147
worknprog.99
Originally Posted by Bad99Olds View Post
Keep going.
thats the plan
lol
Old 05-05-2009, 09:29 PM   #148
Ew, same side I/O.
Old 05-05-2009, 10:21 PM   #149
worknprog.99
Ew, same side I/O.
why you say ew?? thats not a same side intercooler in that pic
Old 05-05-2009, 10:33 PM   #150
I commented on both of your points in the quote. Did you not see that? You wanted to see what my intercooler looked like. Then you mentioned you wanted a same side intercooler.
I answered both.
Old 05-05-2009, 10:55 PM   #151
worknprog.99
oh lol.... why are you against the inter coolers with the inlet and outlets on the same side?? i would think it will make piping very much easier
Old 05-05-2009, 11:11 PM   #152
Well on your setup it would make things easier. I just don't like how they look.
Old 05-05-2009, 11:14 PM   #153
worknprog.99
yeah i like the other kind better but for time manegement i may get one .. however there is a guy locally that will sell me one that looks identicle to your for 40 so i probably will go for that one even though it will be harder...
how would i run the piping back up through the hole to the intake?
Old 05-06-2009, 05:37 PM   #154
worknprog.99
...also im looking at oil return lines any recomendations for that?
Old 05-06-2009, 05:43 PM   #155
Bad99Olds
New and Improved
Bad99Olds's Avatar
Really?
As for oil return lines, im not sure. I know Richie (AftermathAlero) has a lot of parts, but im sure someone will give you a decent answer soon enough.
Old 05-06-2009, 06:51 PM   #156
Yeah... you get some -10AN braided stainless steel hose, fittings to fit on the turbo's outlet, and either a bung or a fitting to weld into the oil pan and screw on your hose with its fitting.
Old 05-06-2009, 07:33 PM   #157
worknprog.99
just picked up this intercooler from a guy on craigslist for 40 bucks
its a jdm
Old 05-06-2009, 08:47 PM   #158
worknprog.99
ok so for those that have done this or those that have no how... i was just out looking at the manifold to see how i was going to run the new turbo manifolds... now i have two designs, 1 i dont think will work because of clearence issues around the corner of the motor.... so idea two looks like what aftermath did. now my question is to combine the front and back manifold parts together and go into the turbo wont be to hard, the problem i see is when you disconect the downpipe from the back log and run a pipe from the outlet of the turbo to the downpipe that would leave the old hole where it was bolted to the back log,, so would you just bolt on a closed flange to "plug" up the hole??
'sorry for the long post
Old 05-06-2009, 09:45 PM   #159
Ya. _
Old 05-06-2009, 10:12 PM   #160
worknprog.99
Ya. _
so that is correct you just bolt on a closed flange as a "plug" ?
my other idea was cut back the downpipe (have to anyways) and put a 90 degree elbo from the stock DP hole and run that to the inlet and then run the downpipe from the turbo to the exhaust to the back,..... only problem with this idea is pipe clearance on the side... here is a rough diagram of tha idea.. although the "plug" the hole idea is probably how i will go.
bad very rough thought of possible manifold mod. probably not enough room for piping with this way but just a thought.
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
