03-25-2009, 01:22 PM
New Engine
Well i couldnt hold it in anymore  i just put payed a deposite to OEM engenering from j-body to build my LD9 motor which includes the follwing:
9.1 Wiesco Pistons
2.3 Oil Pump
P&P Head
Bore 20 Over
SS valves (1mm over)
LMZ stage 2 cams Valve Lift INTAKE 260* - 377 EXHAUST 268* - 375
Bronze Valves Guides
Machine Block for 2.3
Rebuild Head
Boil Block
Arp Main bolts
Arp Head studs
Stiffer mantapart springs(Not to crazy about them but OEM says they have it in there 2.4 and its doing fine)
Eagle Forged Rods
Cometic Head gasket
Ill be updating with pics as soon as i get them.
03-25-2009, 01:23 PM
This sounds like a monster.
03-25-2009, 01:26 PM
You got beat by an Alero!
I will def be checking back to see the pics cause I also have the 2.4 and am interested to see what it looks like and how it turns out
03-25-2009, 01:52 PM
Sweet, Marcus is a good guy.
03-25-2009, 02:13 PM
Planning on feeding it escargot?
03-25-2009, 02:17 PM
Female.
sounds beastly.
2012 Hyundai Veloster - new 40 MPG DD!!
1990 Nissan 300ZX Twin Turbo 5 speed - "Zeus"
2005 Nissan Titan SE King Cab 4x4 - gas guzzler
03-25-2009, 02:34 PM
Sounds great!
Keep us updated
03-25-2009, 04:10 PM
9.1 Wiesco Pistons
2.3 Oil Pump
P&P Head
Bore 20 Over
Secret Cams
Rebuild Head
Boil Block
Arp Main bolts
Eagle Forged Rods
Cometic Head gasket
Sounds like my motor at the end of the month, except mine will be higher compression, and rev 7200+
03-25-2009, 05:20 PM
Let's Play Army!
took me a sec to realize you meant turbo. haha
yeah, that sounds like a hell of a setup. keep us posted!
Originally Posted by black
03-25-2009, 05:25 PM
New and Improved
looking good bro.
03-25-2009, 05:31 PM
sickness! its gunna be one mean setup
03-25-2009, 06:03 PM
Ya mines going to around 7k what compression are you going to run?And what springs are you running cause OEM going to get the springs from mantapart which im not crazy about but i havnt seen any other after market springs for the 2.4 i saw people on j-body running 2.3 springs
03-25-2009, 06:04 PM
Ya im going to run a snail with meth
03-25-2009, 08:21 PM
Depending on my cam setup, I'll be winding her out to between 7200-7800rpm, the springs I'm going to run? Well I did make a few phone calls to a few places that may be able to help me out. Worst case scenario, 2.3 springs which I already have. Best case scenario, something better.
Compression right now w/ the headgasket I'm running, it is going to be 9.5:1 compression.
The car is going to have tunes for E85, 100octane, and a c16 map.
I've also changed my mind on turbos again, :-\. No more GT4088R, I'm going with a BorgWarner unit. However still shootin for 25lbs of terror.
I wouldn't touch Mantapart with a 50ft cattle prod. I dont trust them at all. My original set of pistons that I'm still running took them 6 months to get to me. They sent them without rings. Then sent me rings and shorted me a set of rings. Then I had to bitch for another set of rings. Never would answer the phone, would gladly take my money, always were a pain in the ass. Sent me a piece of shit exhaust flange that is worth only the metal it was cut on. They need to go under.
03-25-2009, 08:55 PM
That is going to be a monster set up im very jealous
03-25-2009, 09:56 PM
I'm jealous of both of your guy's engines.
How much money do you have in the engine alone?
99 Alero 3.4l GLS - Totalled
95 Avenger ES - Sold
01 Alero 2.4l 5spd - Sold
06 Mazdaspeed 6 - Current Vehicle
03-25-2009, 10:40 PM
Its going to run 3400 ish for parts labor shipping and machine work
03-25-2009, 11:39 PM
I'm 90% positive I'll find something to break after three or four trips to the track. :-p
03-26-2009, 12:11 AM
Elevens??
03-26-2009, 02:31 AM
That's a given.....
