Old 01-03-2011, 02:34 PM   #1
irondiezl3
irondiezl3's Avatar
firewall grommet where pcm wires are help :/
i ran my power wire through the rubber grommet where the wires to the pcm go. i got it through but the grommet came lose and now i cant get it back into place. the rubber is so thick and hard i cant get enough force to flex it back into the firewall hole any tips tricks ideas?
Old 01-03-2011, 02:51 PM   #2
use a screw driver to help push small sections of it back in? Might work.
Old 01-03-2011, 02:53 PM   #3
push harder. thats really all there is to it...
Old 01-03-2011, 03:34 PM   #4
irondiezl3
irondiezl3's Avatar
harder did it lots of elbow grease man those r so tight.
Old 01-03-2011, 03:38 PM   #5
...for a reason....
Old 01-03-2011, 04:10 PM   #6
irondiezl3
irondiezl3's Avatar
random question my headunit has a option to turn the amp inside it off. with that i dont have to disconnect the wires on the radio harness for the speakers do i since i was going to run new speaker wire from the amp im installing straight to the speakers themselves. also my amp has 2 30 amp fuses in it so i need a 60 amp in my power wire fuse right? the amp kit came with a 150 but i think thats too much.
Old 01-04-2011, 01:28 AM   #7
Acutally, you pull the black part out of the grey part... Then you re-seat the grommet to the firewall.. Then re-install the black part.
