Old 02-25-2015, 05:49 PM   #1
Netuddki
Netuddki is on a distinguished road
Where is the Daytime Running Light Resistor?
I would like to know, where to look for the Resistor in the original US Alero.
I have a 2004 (2.4L) "Chevrolet" Alero and I don't have Daytime Running Light, because it is disabled in the EU originally.
I am not sure if it is removed or just unplugged, so I would like to know, where to look for it.
I want to install LED Daytime Running Lights and before I buy a cheap China Resistor or an original replacement, I would like to check if I have to.
Thanks for any help in advance.
Netuddki is offline   Reply With Quote
Old 02-25-2015, 06:57 PM   #2
I'm not sure if it'll work with the"Euro"headlights as they are a different bulb than ours... either way it's in the fuse box under the hood and I'm pretty sure it's relay # 21...
Old 02-25-2015, 07:03 PM   #3
I think its relay #22, look on under side of fuse box cover and look for "DRL" and it should tell you what relay.
Old 02-26-2015, 02:05 AM   #4
smccarthy1883
smccarthy1883's Avatar
smccarthy1883 is on a distinguished road
It's 22 for sure. That's the one that I took out to disable mine.
smccarthy1883 is offline   Reply With Quote
Old 02-26-2015, 04:44 AM   #5
Netuddki
Thanks for the answers. I will look for it.
I want to install external LED lights next to the fog lights, so it's not a problem if the head lights don't have it.
I am just not sure, if I can use the original system for it or should I buy one of those controler units if I want the LED lights going on and off automatically based on weather the headlights are on or off.
Old 02-26-2015, 05:43 AM   #6
Netuddki
I found the #22 in the fusebox and it's there.
I still don't have DRL.
What to do now?
I assume, I need this:
But where is it?
