You power wire is rated by your max amperage. However, a 700 watt amp does not mean that you automaticly use 700 watts. For starters, the max power rating at 4 ohms non bridged will be half of what the max rating would be. That said, your most possibly used could be 350 on a 4 channel setup. If you are running mids and highs, cut it in half again. Low frequencies below 200 htz are what start to use wattage. Unless your speakers (even components) are being bi-amped the tweeter will cause your mids to loose potential wattage. Since the tweeter is more efficient, as you raise your volume it causes your woofer to be less efficient. This is where the benefit of bi-amping comes into play.
