Old 12-05-2005, 07:36 PM   #1
shockz
Alright... so I give my car to my brother in August. It was normal when I gave it to him.
I came home for break and decided to give the Alero a drive (man do I miss how easy it is to steer that thing... I was shocked at easy it was to move that wheel). Well I turned the car on and heard a "scrape" sound. As I got down to my driveway I gave it a little gas and it made the scrape sound again. So I kept an ear out for the sound. Every time I started acclerating I heard the sound, but when away when I got to 5-10MPH. When going on the freeway I brought it up to 65. During the 2500-3900 RPM range the scraping sound is continous. It sounds pretty bad.
I have the 2.2L ecotec with a 4 speed auto. 2002 GL.
Anybody have any ideas or clues to what it might be?
Thanks
shockz
Old 12-08-2005, 11:16 PM   #2
shockz
Anybody?
Old 12-08-2005, 11:42 PM   #3
alerocar01
alerocar01's Avatar
alerocar01 is an unknown quantity at this point
how many miles are on it?
DO WORK
alerocar01 is offline   Reply With Quote
Old 12-09-2005, 01:59 AM   #4
shockz
It's got 68254 miles on it.
Old 12-09-2005, 12:37 PM   #5
Wheel hub?
Old 12-09-2005, 04:12 PM   #6
alero_ecotec
Special Agent
alero_ecotec's Avatar
alero_ecotec is an unknown quantity at this point
deer antlers lodged in exhaust
THE Ohio State University!
alero_ecotec is offline   Reply With Quote
Old 12-10-2005, 01:01 AM   #7
shockz
Originally posted by Redog@Dec 9 2005, 01:37 PM
Wheel hub?
Thats what I thought at first too, but the sound happens when the car turns on. It also occurs when the car is in Park and you give the car a little gas.
Old 12-18-2005, 02:14 AM   #8
shockz
Looks like the problem was the heat sheild for the exhaust.
Old 01-09-2006, 03:22 PM   #9
slalomking
slalomking is an unknown quantity at this point
My driveway has a 'hump' or 'berm' at the top as you enter/exit the driveway. It scrapes the heat shield every time due to the low clearance.
It sounds like of you slid the flat side of a metal yard rake over an open weave metal sidewalk grate. Can't describe it in words, but that is the best 'visual' i can give.
It's easy to see and inspect. If there are no bends, folds, tears, or fresh scrape marks, then at least you can eliminate it as a suspect.
'03 Ruby Red GL1 4 Dr, Ecotec auto. All options but leather. 16 inch factory Argent wheel upgrade, Potenza RE910s, Powerslot front rotors, factory deleted cargo net replaced. Hi/lo beam Silverstars.
slalomking is offline   Reply With Quote
