Old 12-07-2005, 09:29 PM   #1
DarkStar
DarkStar is an unknown quantity at this point
hey guys, i just ordered a set of 12 inch kenwood subs and an ampfor my alero, i was wondering, will the subs and amp work with the stock cd player?
thanks
DarkStar is offline   Reply With Quote
Old 12-07-2005, 10:26 PM   #2
not w/o line level converters.
not sure where to get them, or hook them up. try doing a search for them.
Old 12-07-2005, 10:44 PM   #3
DarkStar
hey would this work? http://www.audio-warehouse.com/web/mdl/NS60/detail.asp
Old 12-07-2005, 11:14 PM   #4
bigd6983
thats what u want........aslong as ur amp is a 2 channel amp that is what u need.....most people tap off the rear speakers........short rca run
Old 12-08-2005, 08:34 AM   #5
DarkStar
ok thanks alot guys
Old 12-08-2005, 09:48 AM   #6
if you have mroe than a 2 channel amp, just get "Y" connectors at radio shack and you can hook up a 4 channel as well...
Old 12-08-2005, 11:07 AM   #7
Str33tRacer
Even if you can i wouldnt recomend it. Its gunna sound like crap because of the wattage the stock deck puts out
Old 12-08-2005, 11:10 AM   #8
whiteliquid
Defeat < Giving Up
whiteliquid's Avatar
whiteliquid is an unknown quantity at this point
Send a message via MSN to whiteliquid Send a message via Yahoo to whiteliquid
what year is the car?
WhiteLiquid
whiteliquid is offline   Reply With Quote
Old 12-08-2005, 05:14 PM   #9
DarkStar
even if i can what?
and its a 99
Old 12-08-2005, 05:43 PM   #10
Str33tRacer
even if you can hook it up that way, Wait and then get a good enough deck like alpine
Old 12-08-2005, 05:49 PM   #11
DarkStar
hmm, how much is that gonna run me?
Old 12-08-2005, 08:42 PM   #12
Str33tRacer
depends, go to best buy circuit city talk to them, see what they have about 250-350 give or take, if you want little dalphins dancing on yer dashboard while listening to music, that will cost more i have the best alpine deck that circuit city offered, i forget the name but it was like oh... 320 and it puts out alotta wattage, enouggh for any sub combo
Old 12-09-2005, 08:39 AM   #13
whiteliquid
Defeat < Giving Up
Wondering the year because, 03's and up require a different type of wiring harness for the deck than the 02 and below. It's like a 116$. I bought 2 because i thought i had the wrong one the first time because my door speakers wouldnt work. But it's just really complicated. You have to wire it some wierd way.
But you have a 99 so all that i just said was pointless lol
WhiteLiquid
Old 12-09-2005, 11:47 AM   #14
kimosabea
since the 6X9 in there rear of most aleros are to channel, that means you could tap into the low side of the wiring and if you amp has high level inputs it it would pick up sound though the back speakers. as long as you make sure you hook into the low side of the wiring you should be fine. thats how i did mine and it sounds good. im sure it would sound better with a aftermarket deck but i saved some money and could always do it later
Old 12-17-2005, 12:26 PM   #15
halfJ99
well it isnt like you have to spend that much on a cd player to get a good sound...i got a jvc arsnel (sp?) for $140 at americin ..i really like it
Old 12-17-2005, 01:19 PM   #16
DarkStar
i think im just gonna go with the line level converter, but what part of the cd player do i hook it up to..?
Old 12-22-2005, 04:43 PM   #17
DarkStar
well i got a cd player, an RVC and i took the old cd player out, but i cant find the ground and the positive wire, like i said its a 99 alero, but do any of you know what color the power and the ground wire are?
Old 12-22-2005, 09:44 PM   #18
DarkStar
oh, and do the front speaker grills just pop out? the ones on the bottom of the door? or do i have to take the door apart?
Old 12-23-2005, 02:08 AM   #19
shaunweimer
First of all...... don't do anything unless you know what you are doing, with a line level converter you need to tap into your harness. you need a Wiring diagram. second you will screw the door up if you try and pry/ pop the grills out you have to remove the red reflector and that piece underneath your door handle and you should see a total of 3 screws to take out then gently put a flat head screwdriver in the panel and start to pry towards yourself and pop pop pop its off but watch out for wires as the will need to be unhooked from the plugs. your best bet would be let the people who know what they are doing mess with it. if your from ohio and are close to columbus i could do it all in about an hour. i've taken my car apart many of times and could do it in my sleep lol.
Old 12-23-2005, 04:01 PM   #20
DarkStar
hmm, no i got it all hooked up now, but when i turn the car to acc, the cd player turns on and then turns off.
any ideas?
