Old 12-14-2005, 11:25 AM   #1
alerostealthracer
When I turn my headlights on, my guage cluster lights, such as the speedo, don't come on. the ses lights and those sort work, but the tach and speedo lights dont....i checked the fuse panels and box and couldn't find the blown switch.......any ideas?
Old 12-14-2005, 01:26 PM   #2
AftermathAlero
does the parking lights outside work too? if not then you fuse blown, it is under the hood fuse box. not the inside one. But you should get a SVS light too.
If the outside parking lights work, and the interior lights dont work. You blew a fuse on the passenger side interior fuse panel.
Those are the only two options. Check those.
Old 12-15-2005, 02:09 PM   #3
alerostealthracer
aight, i'll check that, they do work....ill get back thanks dood
Old 12-15-2005, 02:34 PM   #4
alerostealthracer
the parking lights and interior lights work, but not the clutser.....
Old 12-15-2005, 03:36 PM   #5
AftermathAlero
hmm so all the ac control lights work (unless u have a stock radio too)? that would be the only interior light besides the cluster connected to the parking lights
when i said interior lights before in the other post. I didn't mean dome light, mirror map lights. My bad for not clearing that up.
Did u check those fuses on the right side of the dash (passenger side panel) ??
