12-14-2005, 06:20 PM
A few people have said they will fit, but being higher wattage, I wouldn't want to melt a projector or a harness. Has anyone here run these for a decent length of time?
12-14-2005, 06:56 PM
nope you'll be okay up to ~ 50 watts
12-15-2005, 09:24 PM
^ No 35 watts in the fog light
12-16-2005, 12:59 AM
Hmmm... 50/50 split so far. Talk about torn!
I'm still considering lots of options, ranging from higher wattage in the stocks, to better projectors bolted on!
12-16-2005, 06:04 AM
fogs are 35 watts
12-16-2005, 06:12 AM
are yo usure they arent 37.5?
correct me if im wrong
AUTOBOT
12-16-2005, 04:15 PM
894 bulbs originally, i think Sylvania does 893's which are 37.5 watts
if i'm right they're the same as the 894's, not positive but it sounds right to me
smirking is important
follow the titans
12-17-2005, 12:46 AM
I know Osram Sylvania 894's are 37.5 watts.. mostly 894's are in the mid 30's as far as wattage... my question was, has anyone run 886's (much higher wattage!) with a stock setup! I only ask because some people, including Naich, say they fit... I just want to know if I need to upgrade the harness before hand, to avoid melting wires!
12-17-2005, 09:31 AM
They will fit in the fog light hardness but the bulbs will not do any good to your wiring.
A while ago I bought the 880's to put in my fogs becasue I wanted Silverstars and that is the only fog bulbs they made. They were 27 watts, and the bulbs blew out very quickly, prpbably within 3 weeks. Both blew out on a road trip to IN in the snow.
I figered that 10 watts less wouldn't make a difference, but it cost me $40 for a set that lasted 3 weeks. You go 15 watts higher, it could cost you much more
12-17-2005, 10:52 AM
The cost of Silverstars really is obscene. I thought of the 880s but didn't bother because Walmart wanted I think $18 bulb. Anyway I've decided against the 886's.
