Old 12-14-2005, 09:37 PM   #1
Stanl3yX
Stanl3yX is an unknown quantity at this point
Send a message via AIM to Stanl3yX Send a message via Yahoo to Stanl3yX
i have rough idling and after searching i guess i got to clean the IAC sensor. could somebody tell me where its located? a picture would be helpful?
New and Want to MOD
I have 2000 Red Alero
2.4L Twin Cam with 15" Tires
Stanl3yX is offline   Reply With Quote
Old 12-14-2005, 11:15 PM   #2
Oldsman
Owner
Oldsman's Avatar
it is located on the intake tube between the plastic box on the throttle body and the air cleaner box.
Beware of the BackStabber
Old 12-15-2005, 10:01 AM   #3
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
it's the easiest sensor to find when you get a new intake.
Old 12-15-2005, 10:06 AM   #4
freeze12
You probably have to clean the IAC valve on the throttlebody with some throttlebody spray as the valve carbons up after a while.
...Dan...
Old 12-16-2005, 09:54 AM   #5
Fast Eddie
That's the IAT sensor. I don't think there is a IAC sensor, just a valve like freeze said.
I'm on a boat.....
Old 12-16-2005, 03:41 PM   #6
UnoWHO
Its the idle air control, if you follow the filter box through all the tubing there will be a square piece of metal prol 5in by 5in at the end of the plastic intake tubing, on the piece of metal is the IAC its the biggest sensor/motor there and its only screwed in using 2 screws. throttle body cleaner is what youll need to clean it
Old 12-16-2005, 06:56 PM   #7
freeze12
Originally posted by UnoWHO@Dec 16 2005, 03:41 PM
Its the idle air control, if you follow the filter box through all the tubing there will be a square piece of metal prol 5in by 5in at the end of the plastic intake tubing, on the piece of metal is the IAC its the biggest sensor/motor there and its only screwed in using 2 screws.Â;-) throttle body cleaner is what youll need to clean it
He has a 2.4 motor...the IAC is on the throttlebody. Facing the car looking at the TB,it is on the left side of TB. Just look inside the TB & on the left side of TB (front) You will see a hole on the inside of the bore of the TB. That is where you spray the cleaner.You cant miss it!
...Dan...
