Old 12-26-2005, 03:12 PM   #1
firstson
firstson is an unknown quantity at this point
I got everything off in the back and took the old speakers back but now when i'm going to but the new ones in, there are 4 wires to the car, but with my new speakrs there are only 2 wires for each. what am i suppose do to with a 4 and 2 wires?
firstson is offline   Reply With Quote
Old 12-26-2005, 03:27 PM   #2
lol, you my friend have the monsoon system. You can go 1 of 2 routes at this point. You can either buy an adapter to take it from 4 to 2 or you could just run speaker wire back from the headunit. That is the route I took when I replaced mine.
Old 12-26-2005, 03:47 PM   #3
firstson
Where can you get the adapters?
Old 12-26-2005, 04:30 PM   #4
firstson
Scratch that....on the old wiring harness, what colors are positive and negative for either side. i just talked to a guy from crutchfield and he said thats all you have to do and just tape off the other 2
Old 12-26-2005, 07:18 PM   #5
firstson
OK scratch that again...i have them hooked up but when i turn on the radio the speakers don't work until i tap them. is this like a grounding problem or what?
thanks
Old 12-26-2005, 08:33 PM   #6
mikegett
mikegett's Avatar
You can't just use two wires. The monsoon is two seperate amps running mids to highs and lows to the same speaker. This is called bi-amping. If you use one set of wires then you will only get the low frequencies or the mid and high frequencies. Above all, do not splice them all togeather. This would literaly be running two amps onto one speaker. Do as stated earlier and run the speaker wire from the HU directly to the new speakers. You won't get the benefit of the extra wattage but you will get all frequencies.
Old 12-26-2005, 08:34 PM   #7
mikegett
mikegett's Avatar
Could we possibly get a sticky on this subject? It seems that once a month this same question comes up?
Old 12-26-2005, 08:47 PM   #8
firstson
Alrght, how do you run the wires from the h.u. to the speakers? that sounds like it could get complicated
Old 12-27-2005, 09:04 AM   #9
that is the easiest. Just find the wires for the rear speakers in the wiring harness up there at the head unit and take some regular speaker wire, hook it up to the harness and run it back to the speakers. Its a piece of cake.
Old 12-27-2005, 09:18 AM   #10
firstson
Ok so i take the rear speaker wires from the head unit...splice speaker wires to those and run them back to the speakers and splice them there. When you say speaker wire is there like a specific kind i need to be using and where would i run it through the car?
Old 12-27-2005, 10:44 AM   #11
really doesn't matter too much to be honest. YOu dont need anything super thick. Now are you trying to run these from the factory HU or an aftermarket?
Old 12-27-2005, 01:55 PM   #12
firstson
Aftermarket.
would you just like run it under the carpeting or what? and if i do this does that mean i'm just tapin off all the old wiring?
Old 12-27-2005, 03:51 PM   #13
firstson
Mike i went and checked the bass, treble and middle and the rear speakers put out all of them, with just 2 wires it doens't seem like i'm missin anything. my only problem is that when i put the radio on standby or turn it off completely then turn it back on i have to bang on the back seat to get the rear speakers to work. if i just turn down the volume all the way and turn it back up they still work.
Old 12-29-2005, 11:02 PM   #14
mikegett
mikegett's Avatar
How do you have your car wired now. I take it that you have a aftermarket HU. Did you do as suggested and run the rear speakers from the aftermarket HU to the rear speakers? Did you simply wire two of the old speaker harness wires to the new speakers? Banging on the seat sounds like a loose connection but should have nothing to do with turning the HU on or off. If you did not wire the speakers directly from the aftermarket HU then it may be a issue of your monsoon amp turn on signal. Do you loose sound at both speakers or one? Front and back or just back?
