Old 01-13-2006, 10:22 AM   #1
99alero_dude
I wanna find a 4 wheel set of brembo rotors and calipers. Where's the best price tag for 'um? I'd like the bright red calipers that say BREMBO :-p
Old 01-13-2006, 10:32 AM   #2
AftermathAlero
are you talking bout the BIG BRAKE KIT? or stock brembo size rotor replacements? If your talking bout the stock brembo rotor replacements.. you can get those on www.tirerack.com for like 50 bucks each rotor. If your talking bout the BIG BRAKE KIT... Brembo does not make them for our car. Only BAER and SSBC does. and for all 4 wheels will run you about $1600 bucks - $2000 bucks.
Old 01-13-2006, 01:06 PM   #3
99alero_dude
Stock size sir, and thanks too.
Old 01-13-2006, 02:04 PM   #4
14alero
14alero's Avatar
14alero is an unknown quantity at this point
Send a message via Yahoo to 14alero
Hey 99 alero I know a place you can get the Brembo Rotors Cheap Pm me and ill tell you
14alero is offline   Reply With Quote
Old 01-25-2006, 03:06 AM   #5
Wild Country
Wild Country's Avatar
Wild Country is an unknown quantity at this point
Send a message via AIM to Wild Country Send a message via MSN to Wild Country Send a message via Yahoo to Wild Country
i was thinkin about this too... ill check tirerack.
Chris
Wild Country is offline   Reply With Quote
Old 01-25-2006, 01:14 PM   #6
Fast Eddie
If you want the "bright red calipers that say BREMBO" (like these)
then you are talking about new calipers and probably a conversion kit. They don't make em for our cars and if they did they would run more than $1200+ (probably closer to 1500) for the front end alone.
I'm on a boat.....
Old 01-25-2006, 10:30 PM   #7
Spilner521
Boost Guru
Spilner521's Avatar
the only way would be to buy brembo calipers and have adapter plates made to attach the brembos where the stock calipers go...i plan on doing this eventually, but not with brembos and i'll be making my own big brake kit, probably with endless or rotora brakes.
Old 01-26-2006, 04:37 PM   #8
99alero_dude
Brembo big brake rotors are good enough for me, hell with $1200-1500 brake kit. rofl. Maybe when I get rich.
Old 01-26-2006, 04:58 PM   #9
Fast Eddie
The rotors aren't bigger either, they're OE size.
I'm on a boat.....
Old 01-26-2006, 08:37 PM   #10
PrImEtImE
PrImEtImE is an unknown quantity at this point
I got the brembo rotors off of ebay...they costed me 230.00 shipped plus i got some pads, no calipers though. You could check ebay but I haven't seen them on there since I got them.
PrImEtImE is offline   Reply With Quote
Old 01-27-2006, 03:37 AM   #11
Fast Eddie
LMAO. You can get them from tirerack for 52/ea for the front and 49 each on the rear. Cheaper than ebay, even if you go all the way around
I'm on a boat.....
Old 01-27-2006, 10:27 AM   #12
PrImEtImE
the ones on tirerack are a plain finish. The ones I got are drilled & slotted so that might be where the price difference comes in
Old 01-27-2006, 11:34 AM   #13
Fast Eddie
and your sure they're Brembo rotors?
I'm on a boat.....
Old 01-27-2006, 12:13 PM   #14
PrImEtImE
almost positive. On ebay it was like an auto parts place that wholesales car parts. On ebay they were advertised as brembo rotors, so I'm assuming thats what they are. If there not they look awesome and work very well with the new semi-metallic pads I got with them. As a matter of fact dude, go on ebay and type in brembo rotors for alero, they should come up. They are priced at 195.00, I just seen them again today.
Oldsmobile Alero [99-04] BREMBO Drilled Slotted Rotors
