01-15-2006, 01:26 PM
Hey guys this is my first post although I've been reading around this place for a while now. Anyway, I think the dreaded LIM leak has showed its ugly face...
I took some pictures so you can tell me for sure if that's it.
[attachmentid=9523]
and zooming in...
[attachmentid=9524]
now on the passenger side:
[attachmentid=9525]
and close-up on the passenger side:
[attachmentid=9526]
01-15-2006, 01:31 PM
how does your coolant look??
01-15-2006, 02:07 PM
those look like the start of it, those are the areas on my car that are wet - and i know I need to change mine in the next week, because now I am starting to get coolant mixed in with oil.
01-15-2006, 02:08 PM
The coolant in the reservoir is just yellow/orange. It doesn't look like sludge (maybe there's no sludge if it just started leaking?)
01-15-2006, 02:57 PM
its hard to say for sure what you have. a little bit of weepage is normal. just monitor your oil and coolant levels very closely. often one sign of this leak is a milky residue on the bottom of the coolant resevoir cap.
01-15-2006, 03:09 PM
Thanks for the replies this far
I forgot to mention that my "Change Oil" light came on (about 2 days ago) before i started suspecting the leak.
01-15-2006, 03:51 PM
when is the last time you changed the oil?? and did you reset the light after you changed it??
01-15-2006, 05:57 PM
well the gasket leak can be 2 things.
either just coolant leaks, just oil leaks, or they both leak and mix...
if its just oil, sometimes its normal sometimes its not, mine slightly weeps a bit of oil from the sides every few weeks, which is not a problem cause its little to none.
AUTOBOT
01-15-2006, 05:59 PM
and your motor looks 10 years old, you need to clean that thing....
and is that your fuel pressure regulator rusting and your fuel rail.......? :Noooo:
AUTOBOT
01-15-2006, 08:13 PM
Well I bought the car about 3 weeks ago so I'll be taking care of the motor cleaning as soon as it's not freezing cold outside.
As for the oil, the dealer i bought it from said that they changed the oil while the car was there. If that's true or not, I don't know.
Trust me, I don't like seeing the motor in a bad shape, just give me some time :P
01-16-2006, 12:56 AM
mine leaked in the same exact spot on the drivers side. it was leaking into the oil also. get it changed asap. it gets worse in the winter, it's when i really started noticing it with mine, especially with the lifter ticks from the oil not being able to lubricate properly.
