Old 01-26-2006, 03:55 PM   #1
Alright, I dug this up over at GAGT.com. They have the part numbers to order just the plastic pieces from gmpartsdirect.com. here you go...
Part Numbers
22697623
22697622
Old 02-15-2006, 10:03 AM   #2
dbailey
dbailey is an unknown quantity at this point
Are those GM part numbers?
dbailey is offline   Reply With Quote
Old 02-15-2006, 11:55 AM   #3
yes
Old 05-08-2006, 01:27 PM   #4
Whitetigerboi83
Whitetigerboi83's Avatar
Whitetigerboi83 is an unknown quantity at this point
Send a message via AIM to Whitetigerboi83 Send a message via MSN to Whitetigerboi83 Send a message via Yahoo to Whitetigerboi83
not the part numbers i have ... 4 door 02 # 022689012 $9.78 each now anything special i have to do to put them on ???
Whitetigerboi83 is offline   Reply With Quote
Old 05-08-2006, 02:14 PM   #5
dbailey
WOW! Do the dealer will sell the plastic pieces seperately!?
Old 05-08-2006, 03:50 PM   #6
Whitetigerboi83
thats where i just got mine from
Old 05-08-2006, 05:45 PM   #7
Whitetigerboi83
ok my bad those are the expensive ones that connect to the regulator cable.. i just found my passenger one snaped thats why i had to buy the 9012 one that connects to the glass too
37.58 at dealer for the 7622
Old 05-08-2006, 05:54 PM   #8
acold7dusta
i had to do this on my buddys GA and it was a pain to get em on n off, and it did cost him cost to 60 bucks
Old 05-08-2006, 08:07 PM   #9
Whitetigerboi83
my prob was i thought i just needed the white clip that attached the regulator to the window it had come unglued but i didnt feel like trying to clean it and put it back on thats when i saw my clip on the regulaor was broken on the same one that wasnt attached to the window 38 bucks all together.. it a small problem but i'd rather not have my window fall down and break inside the door
Old 05-12-2006, 04:31 AM   #10
RoninKouga
my driver side window doesn work anymore.
its like the swich diesnt work, there's no power consumption in the door when i switch the key, will this plastic pieces solve my problem?
Old 05-12-2006, 09:50 AM   #11
Whitetigerboi83
either its your switch or the regulator is fried
Old 05-12-2006, 01:04 PM   #12
jackal2000
jackal2000's Avatar
ya that white clip is weak, i had to replace both of my drivers side ones, at separate times of course. the dealership by me said that when they ran out of the white clips you have to buy a whole regulator kit, i got lucky that they had one and it gay to do something like that.
Old 06-10-2006, 11:32 PM   #13
MixtapeMessiah
Southern Fly Boy returns
MixtapeMessiah's Avatar
I had to replace two already my regulator for my driverside window is fried too. How much did it cost u at the dealer to get and put on? Im thinkin bout just gettin new regulators and motors for all the other ones that need it. I hate havin that problem here in Houston weather, its gets hot as hell
Old 06-12-2006, 02:15 PM   #14
alero440
alero440's Avatar
alero440 is an unknown quantity at this point
Send a message via AIM to alero440 Send a message via MSN to alero440 Send a message via Yahoo to alero440
My cost those pieces were like $5 a piece. So they are prolly like $8.
alero440 is offline   Reply With Quote
Old 06-14-2006, 11:39 PM   #15
Sundayalero
Sundayalero is an unknown quantity at this point
Does anyone have a pic of what that part looks like broken? I searched but could not find one....
<span style=\'font-size:8pt;line-height:100%\'>Every now and then when your life gets complicated and the weasels start closing in, the only real cure is to load up on heinous chemicals and then drive like a bastard from Hollywood to Las Vegas. Just roll the roof back and screw it on, grease the face with white tanning butter and move out with the music at top volume, and at least a pint of ether.
-From the book Fear and Loathing in Las Vegas by Hunter S. Thompson </span>
Sundayalero is offline   Reply With Quote
Old 07-15-2006, 10:49 AM   #16
djskunkdiesel
Hellz Jeah
Man my drivers side window doesnt want to come up sometimes, then I can pull the switch panel up out and it will magically come up? Not sure if its some kinda of loose connection or weather the motor is slowly crapping out. Im just scared that thing will get stuck in the down position... have any of yall had to replace the window motor?
Old 07-15-2006, 11:54 AM   #17
IRONDOG442
IRONDOG442's Avatar
IRONDOG442 is an unknown quantity at this point
Send a message via AIM to IRONDOG442
Have fun drillin those damned rivets out. What a PITA
IRONDOG442 is offline   Reply With Quote
Old 03-04-2007, 10:09 PM   #18
stinger
RE: Window Regulators
I have to replace to power window regulator on the passenger side. Can anyone provide me with an illustration of the inner workings and how I replace the regulator? Thanks.
Mark
Old 05-04-2007, 02:04 PM   #19
NeonStatus
NeonStatus is on a distinguished road
Is there a DIY on how to replace this? I figured it would be here in the sticky but I guess its not. I searched and didn't come up with anything.
NeonStatus is offline   Reply With Quote
Old 05-18-2007, 01:58 AM   #20
StackS 757
StackS 757 is an unknown quantity at this point
Got mine fixed today.. was $239.59 out the door.. prob couldve been cheaper if I bought the part myself.. some of the dealerships were talking about $750.. glass shops are much cheaper..
[22:38] Schmoove: my roomate was like is that your boys car?
[22:38] Schmoove: first I thought u stole some poop
[22:38] StackS 757: haha
[22:38] StackS 757: y he ask that
[22:38] Schmoove: then he was like that boy got crazy bass
[22:38] StackS 757: lol
[22:39] Schmoove: lol
StackS 757 is offline   Reply With Quote
