Old 01-29-2006, 11:36 PM   #1
exnine@gmail.com
exnine@gmail.com's Avatar
exnine@gmail.com is an unknown quantity at this point
Send a message via AIM to exnine@gmail.com
I'm not sure if this is due just to the cold, or if it's maybe something bigger.
But sometimes If I go out to turn my car on I put it in the on position, I almost always let it sit for a moment (habbit) and then I turn the key in to start possition and wait for it to crank on. Well sometimes it will Jump on really fast. like within a split second. and other times it will usually turn a couple times before it jumps on. leave you waiting for a few seconds.
It's not a major thing. It almost always comes on unless something is wrong.
It seems to go in an order though. forexample. One time I start it. If it seems to take a long time the next time it will hop on really quickly. then it gradually seems to slow down. untill it takes a long time again to start.
I was just wondering if this was normal or not. cause If I go out to my dad's car and start his. (he has an 02 cavalier) it jumps on almost instantly, everytime.
any need to be worried?
Welcome to my sig.
exnine@gmail.com is offline   Reply With Quote
Old 01-29-2006, 11:41 PM   #2
MixtapeMessiah
Southern Fly Boy returns
MixtapeMessiah's Avatar
I dont think its nothing to be worried about, the same happens with my car. its probably due to the temperature, and plus if the engine is cold or hot u know? Dont worry about it tho, but if it isnt even cranking then yeah u got a problem, our cars aint new well mine aint im going on 100.000 miles and the same thing happens with me
Old 01-30-2006, 12:13 AM   #3
exnine@gmail.com
Allright, that's assuring.
I have a 99. And im comming up on 90.000 =O
Welcome to my sig.
Old 01-30-2006, 12:15 AM   #4
MixtapeMessiah
No problem, our babies are just gettin old, I have a 2000 and its comin up on 100,000 miles, its not gonna start like the day it drove off the lot.
Old 01-30-2006, 01:15 PM   #5
Crolero
just a Q, you've got 90k have you replace the fuel filter? If its clogged then you might not be getting enough fuel to startup. I have to replace mine every 6 months because of dirty gas. If it is clogged replace it quick, you might blow your fuel pump.
Old 01-30-2006, 07:47 PM   #6
exnine@gmail.com
I havent Since Ive had the car. So I'm guessing It would be a good thing for me to change it soon.
1) Is it an expensive part?
2) Is it easy to do?
Or should I just Take it somewhere?
Welcome to my sig.
Old 01-31-2006, 06:22 PM   #7
bigd6983
parts about 10 bucks.......all u need is an open ended wrench, wear goggles, its pretty easy....
