Old 02-09-2006, 10:05 AM   #1
alerlow
my power supply is 4 guage wires. and from my amp to my subs is 10 guage wireing all the way through to the sub and before that it was 16 guage and it seemed like there was a major difference in the in the sound and bass quality has any body else expierienced this. it was definently worth the money for the bigger wires
Old 02-09-2006, 10:26 AM   #2
Menace
@Kutztown University PA
Menace's Avatar
Menace is an unknown quantity at this point
Send a message via AIM to Menace
No but now im thinking of it.
Alero is sold!
2007 Scion tC in driveway!!
Stuff for sale
http://www.aleromod.com/forums/showthread.php?t=13919
Menace is offline   Reply With Quote
Old 02-09-2006, 11:15 AM   #3
alerocar01
alerocar01's Avatar
alerocar01 is an unknown quantity at this point
yep bigger wires can carry more current.
DO WORK
alerocar01 is offline   Reply With Quote
Old 02-09-2006, 11:21 AM   #4
Schimmel03
Senior Member
Schimmel03 is an unknown quantity at this point
Send a message via AIM to Schimmel03
What he said. The larger the wire, the more the current. The more the current the more watts you get out of your amp. If you run say, 8gauge power wire you won't get the true wattage out of your amp, because the amp is trying to draw as much power as it can and its not getting enough current through the smaller wire. Thats why most of the cars at sound competitions have 0gauge wire which is friggin huge. The same goes for the subs, the amp is trying to send as much current as it can to the subs, but with smaller wires it can only send so much.
<img src=\'http://www.supermotors.org/getfile/182743/fullsize/sig.jpg\' border=\'0\' alt=\'user posted image\' />
1999 Oldsmobile Alero
White
4 Door
74,000 miles
Twin Cam 2.4L
<span style=\'color:red\'>Let the modding begin!</span>
Current Mods: 2.3HO Intake manifold and Throttle body, Induction Dynamics intake, Unorthadox crank pulley, 15&quot; Kicker CVR, Pioneer Premier headunit, Optima Yellow Top battery, and LED Undercar Lights
Schimmel03 is offline   Reply With Quote
Old 02-09-2006, 01:07 PM   #5
King Asoka
King Asoka's Avatar
yeah, I run 0 gauge power and ground and 8 gauge speaker wire to the subs.
Its a must if you want to get the most out of you Audio set up.
Of course you may not need to go with 0, 4 Gauge power and ground is more than ample for most installs.
Old 02-09-2006, 03:22 PM   #6
aleromod101
4 gauge is plenty enough. Enjoy your set up dont blow a sub or fry an amp.
Old 02-09-2006, 03:59 PM   #7
think about it this way...you are trying to run water through a garden hose. which hose are you going to get the most water out of? the bigger one...so the bigger the better.
Old 02-09-2006, 05:04 PM   #8
himfanzach
also another thing that will get you more power in your trunk is you power wire cut it to the length from batt to you amp dont leave a lot extra the longer you power wire is the more power you will lose
Old 02-09-2006, 05:27 PM   #9
its called attenuation (dont know if its spelled right, but thats what its called)
