Old 02-13-2006, 04:44 PM   #1
Str8tFKNuUP
Str8tFKNuUP is an unknown quantity at this point
Alright, this has nothing to do with my alero, but I got a 93 sunbird 2.0 litre to get me too and from work.
My problem is that the car idles like poop, and when I toss it into gear it starts bogging out but eventually catches up with its self. Soon as I give it some gas it stalls. I also have some serious fuel smell coming out of my exaust added with some whitish smoke, I thought at first it was steam, but its not, cuz it'll stay in the air a while.
I'm figuring that the car is getting too much fuel and is somehow flooding itself out. But I'm not sure where to start and look for the cause. Its multi-port FI. Some one mensioned the fuel pressure regulator. If I rev it up while in park its fine, alittle rough felling but it works, if I put it in gear it wants to die right away, but when I try to move the gar and give a little gas it bogs and dies.
Hope someone can help me on this problem.
<img src=\'http://xxdownloadsxx.2myip.com/strtfknuup/My%20Pictures/7aad03196d79d2a461fa8235fe34dd8d.gif\' border=\'0\' alt=\'user posted image\' />
Str8tFKNuUP is offline   Reply With Quote
Old 02-13-2006, 06:20 PM   #2
Alero2k4
Alero2k4's Avatar
Alero2k4 is an unknown quantity at this point
Maf??? Unplug the Maf and see if theat makes a difference...
1.3l Renesis Rotary
Alero2k4 is offline   Reply With Quote
Old 02-14-2006, 08:31 AM   #3
Str8tFKNuUP
There doesn't seem to be a MAF sensor there.... from what i've read up on, it should be on the duct between the air filter compartment and the intake duct. But I'm not seeing anything on that duct. Would a MAP sensor be the same thing?
Old 02-14-2006, 09:50 AM   #4
Fast Eddie
Check your tranny fluid.
I'm on a boat.....
Old 02-14-2006, 01:06 PM   #5
Str8tFKNuUP
Tranny fluid looks and smells good, I thought of the torque converter/soleniod already. But I've leaned away from that since I can get the car moving some times. It just depends on wether the car is idling better or not. I've tryed in reverse and drive. I do beleive its more of a fuel/emissions system problem... possible the timing or distributor prob. I'm going to test compression this weekend to see if the rings are in good shape.
Any more ideas?
Old 02-15-2006, 02:47 AM   #6
Fast Eddie
cat plugged? fuel pump OK?
I'm on a boat.....
Old 02-15-2006, 06:53 AM   #7
bassboss
bassboss is an unknown quantity at this point
Check your O2 sensor. That's what my prob was on my old Jeep. Same symptoms too.
i know it don't sound right, but hey, it's a cheap part even if it's not the prob.
Good Luck!
bassboss is offline   Reply With Quote
Old 02-15-2006, 08:10 AM   #8
Str8tFKNuUP
ya, it is cheap, i'll run over to crappy tire and pick one up.... what would clog a cat converter? It's fairly new.
Old 02-17-2006, 05:23 PM   #9
bassboss
You said that there is white smoke comming from you're exhast correct?
I hate to tell you but.................................White smoke when first started is normal. If white smoke continues you have an internal coolant leak, i.e., cracked head/blown head gasket. Black smoke is caused by a rich fuel condition. Blue smoke is caused by oil consumption.
That was taken form http://www.2carpros.com/topics/whitesmk.htm. check it out
Old 02-22-2006, 12:48 PM   #10
dbailey
dbailey is an unknown quantity at this point
He's right dude on the smoke colors. Look in your radiator and see if there is an oil slick in it. If there is, its yo headgasket.
dbailey is offline   Reply With Quote
