Old 02-21-2006, 10:33 PM   #1
Menace
@Kutztown University PA
Menace's Avatar
Menace is an unknown quantity at this point
Send a message via AIM to Menace
I have the gauges I just dont have the know how.
Alero is sold!
2007 Scion tC in driveway!!
Stuff for sale
http://www.aleromod.com/forums/showthread.php?t=13919
Menace is offline   Reply With Quote
Old 02-22-2006, 10:26 AM   #2
Easiest way to hook up an A/F guage is to buy the pigtail from PFYC.com and plug it in. one of the O2 sensors is right under the coil, on the 3400 motor. If you don't wanna buy the pigtail, find the sensor plug, it will have 4 wires on it, take the purple wire and spice into it.
Volts is easier. Pull out the radio, and find the igntion wire. It's yellow. Hook the main wire into that and there's your volts. You can also hook into the lighting there too. It's the orange wire.
There are 2 yellow wires behind the radio, one is for one of the speakers. I believe the wires you are looking for are on the right side of the radio.
Old 02-22-2006, 11:12 AM   #3
or just plug the volt one into the "ignition" fuse on the driver's side fuse panel...
Old 02-22-2006, 04:27 PM   #4
Menace
Menace's Avatar
K thanks guys
Alero is sold!
Stuff for sale
Old 02-23-2006, 06:24 PM   #5
2fst4u
[boosted 2.4L]
2fst4u's Avatar
how bout on the 2.4L? is the wire still purple? and where might it be located?
Old 02-24-2006, 02:08 AM   #6
1WhiteOSV
it should be...it's in the o2 sensor plug
Old 02-24-2006, 10:27 AM   #7
I believe all GM cars made after a certain date have a 4 wire O2 sensor hardness.
On a 2.4 it's probably in the front of the motor.
The upstream is in the exhaust header, the downstream is after the cat
Old 02-24-2006, 01:15 PM   #8
2fst4u
[boosted 2.4L]
2fst4u's Avatar
which one is better to tap into? the upstream or downstream?
thanks for the help
Old 02-24-2006, 01:36 PM   #9
Oldsman
Owner
Oldsman's Avatar
hook into the upstream which is on the exhaust manifold.
on 99 the wire in the factory harness is purple but on 00-01 they use a 2 wire O2 so not sure which wire to tap into being neither is purple. you would need to determine which one was the actual signal wire for the PCM.
Beware of the BackStabber
Old 02-24-2006, 01:52 PM   #10
2fst4u
[boosted 2.4L]
2fst4u's Avatar
alrite, i looked up the wiring diagram and they're saying the two tires should be purple and tan. i'm going to have to check.
Old 02-24-2006, 04:09 PM   #11
Menace
Menace's Avatar
K i got the volt gauge working. My air/fuel gauige has 3 wires where do they go? And can someone take a pic of the o2 sensor plug for me pleaseeeeeeee I dont wanna screw with the wrong one.
Alero is sold!
Stuff for sale
Old 02-24-2006, 06:12 PM   #12
Menace
Menace's Avatar
BUMP
Alero is sold!
Stuff for sale
Old 02-25-2006, 12:53 AM   #13
3 wires on the guage, one is for the lighting, one goes to the O2 sensor to read and one is for ground.
This is a pic of the Pigtail from PYFC.com. (it's under the Grand Am section) The purple wire sticking out is the one you would splice into without this. With this, just hook onto the extra wire
Old 02-25-2006, 02:25 PM   #14
Menace
Menace's Avatar
If I just use the stock one I find it right behind the engine correct. To the left of my fuse box.
Alero is sold!
Stuff for sale
