02-22-2006, 01:48 PM
Im about to clear my second headlight, but I would like be able to do it using the oven, seeing how it seems so much eaiser than a hair dryer. Do I need to put it in a pan perhaps wraped in a towl? If this worked for you, be a buddy and share the info.
02-22-2006, 02:38 PM
i put mine on a cookie sheet next to some cookies.
j/k slap it in for 5-7 minutes at 180* on a cookie sheet
02-22-2006, 03:58 PM
i did mine at 150 and left them there for like 5 10 minutes then use some muscle and pull it apart
02-22-2006, 04:01 PM
Is it ok to put in directly on the cookie sheet?
@Kutztown University PA
Yah that stuff that holds them togther is some nasty shaz. I suggest when yuor finished to seal it off with silicone.
02-22-2006, 07:32 PM
yeah dude it is totally safe. The oven doesn't get hot enough to melt anything but the silicon at that temperature. I used a cookie sheet only to prevent any silicon from dripping into the oven, which it didn't. Oh yeah, use oven mitts because it is fairly hot and have something thin and flat ready to pry apart the little clips that are holding it together.
02-22-2006, 07:43 PM
Let's Play Army!
methinks you need to learn how to use a search button before you bake your headlights. I posted a how-to in another n00b's thread this morning.
edit: jesus tap dancing christ! it was YOUR thread!
Originally Posted by black
02-22-2006, 11:19 PM
Hey yea...better safe than sorry man. Headlights arent that cheap to get new so why not go make fun of some other noob trying to mod, kthanks.
For you nice guys, thanks Ill give it a try when I get some time.
02-23-2006, 12:34 AM
VIP
LMFAO thats some good stuff
Gunnery Sergeant Hartman: "I'm going to rip your balls off, so you cannot contaminate the rest of the world."
02-23-2006, 03:25 AM
Let's Play Army!
I wasn't making fun of you. I was merely pointing out that you need to boost your reading and posting skills.
02-23-2006, 02:01 PM
where my knickers at?
^ Agreed... littlebandito, there are at least 3 threads that each contain ALL the info you could ever need to know about EVERY method of clearing your headlights and EVERY precaution to take while doing so. The search button at the top of the page is your friend.
Hope everything turned out for ya.
--UPDATE-- $88,000 in debt.
02-23-2006, 02:18 PM
Just a Q but doesn't heating up adhesive chemicals give off toxic gases? If so them I would not do this in an oven you want to cook in again.
I'm on a boat.....
02-23-2006, 04:32 PM
^ someone never cleans his oven
02-23-2006, 09:38 PM
Let's Play Army!
yeah, it probably does, but guess what? you're not boiling the old silicone on the lights, just softening it. if you were to crank up the heat to boil the silicone, then you'd have problems.
02-24-2006, 12:40 PM
Originally posted by smlzalero+Feb 23 2006, 03:32 PM--><div class='quotetop'>QUOTE(smlzalero @ Feb 23 2006, 03:32 PM)</div><div class='quotemain'>^ someone never cleans his oven
[/b]
I clean both my ovens pretty regular.
Originally posted by AlbinoMonkeyRat@Feb 23 2006, 08:38 PM
<!--QuoteBegin-Fast Eddie
[/quote]
NO your not boiling it but going through a state change (solid to liquid) does give off some fumes. Just like when you outgas alum prior to powdercoating. Or bake powdercoating, it gives off txoic fumes as is most definately NOT something you want to do in an oven you are going to use again for baking edibles. That's why I have a separate oven for powder coating and what not.
If you want to cook Ur LitEs fine its urs brainz.
I'm on a boat.....
02-24-2006, 04:38 PM
Let's Play Army!
that's why you leave the door open a little...let those gases out! There are gases, but it's a negligible amount for the amount of heat and time the lights are in the oven.
02-24-2006, 06:19 PM
techniacally you aren't going through a state change either... you are going from a solid to a softer solid... if it was liquid it's run out of the light...
02-25-2006, 11:15 PM
yeah didnt think of cleaning my oven after words oh well i havent died yet
