Old 03-02-2006, 12:29 PM   #1
Pilate
Pilate is an unknown quantity at this point
My car seems to be periodically turning itself on, in addition when it is really cold out -20 C my alarm often seems to set itself off for no reason. Any tips? The combo is about 5 years old now...self starter just started happening while the alarm issue has been ongoing for several years.
You have not truly experienced ALEROMOD until you clear your corners or paint your bezels.
Pilate is offline   Reply With Quote
Old 03-02-2006, 02:45 PM   #2
1WhiteOSV
do you have a hood pin switch for the alarm?....if you do it could be freezing up and it's probably corroded...this would set your alarm off......as far as the remote starter it sounds like you need an upgrade....a 5 year old remote start is ANCIENT!.....I give it props that it'w worked that long. I'd replace it.
Old 03-02-2006, 04:29 PM   #3
Pilate
THey're a combo unit...and yeh I do have a hood pin, I'll check that out.
