03-05-2006, 11:15 PM
do you actually have to remove the front bumper to get that container out, or just the battery?
03' V6.
seems like its buried in the fender of the car....
03-06-2006, 09:56 AM
Jack up the car...take the tire off..then remove the fender liner & you will have easy access to the washer bottle.
...Dan...
03-06-2006, 12:06 PM
oh. nice! thanks man.
03-06-2006, 05:34 PM
Your welcome. If You did not already pull the washer unit,make sure the washer pump is set correctly in the rubber seal as that will cause a leak.
...Dan...
03-06-2006, 05:45 PM
Let's Play Army!
yes, I've had to do that. the fender liner must come off.
Originally Posted by black
03-06-2006, 07:45 PM
i don't have the time to do it right now, maybe this weekend.
i filled the resvoir, about a month ago, and i noticed it didn't move at all. i didn't think anything of it at the time....
now yesterday, i filled it again, and noticed a line of fluid following me down the driveway as i backed out. (small hill)
what does one of those containers run.... $20?
03-07-2006, 10:08 PM
Let's Play Army!
you want a new bottle? I got one. For free with pick up! You'll have to make sure your pump isn't cracked. That's what my issue was and the extra bottle I have doesn't have a pump.
I have wednesday off all day. PM me
12-10-2008, 03:20 PM
so... i never actually got around to doing this, but it seems to have gotten worse. (need refills more often, doesn't hold it well)
i'm thinking its the motor leaking.
think some epoxy and silicone to cover it will prevent further leaks, or get a new one?
also, i've noticed other posts saying the wiper sprayers tend to freeze up. think a small heater dropped down into the fluid might help that? heat it like... +20 degrees? what is wiper fluid composed of? think a small heater might cause evaporation?
12-10-2008, 03:47 PM
Shit it still seems like alot of work!
12-10-2008, 04:28 PM
what does? getting to the bottle/motor?
12-10-2008, 04:32 PM
some cars come with heated fluid
tis a good idea, mine freezes up sometimes super annoying
12-10-2008, 04:34 PM
you can also add an inline heater to the existing system
12-10-2008, 08:43 PM
Mine hasn't held fluid in about 6 monthes  just haven't had time to fix it. mine is a broken pump though.
12-10-2008, 08:49 PM
Getting to the bottle....Jacking the car up, taking off the tire, then pulling back the plastic wheel liner...Alot work to me, but I try to shy away from that type of thing...LOL
12-10-2008, 08:54 PM
I always take on the fender liner when I race and the bottle is pretty easy to get to form inside, but if I were to remove the bottle, I'd probably take off the wheel too, just for the room to pull the old bottle out.
I switch the filter, and remove the fender liner with just turning the wheels to the left
12-10-2008, 08:55 PM
on vacation
dont forget to put your sensor in right side up.. or your low washer fluid light will come on when its full..
don't ask how i know
WILL NEVER FORGET
12-10-2008, 09:09 PM
yeah, i've been in there before, trying to look at the stock air tubing... should probably remove that too.
anyone know where you can get a inline heater? or a good idea of how to make a little heater to set down in the bottle?
i'm thinking using the same idea i was going to use for the heated mirrors... just need a resistor to limit how hot it gets...
and its not that i need it hot enough to melt the windshield... i need it hot enough to not freeze in the nozzles!
12-10-2008, 09:47 PM
Just start using the de-icer type washer fluid, it costs about a dollar more per gallon but it won't freeze on you.
12-10-2008, 09:49 PM
doesn't help. that IS what i use.
12-10-2008, 10:10 PM
How cold is it up there?
The blue shit freezes at -20 and the Deicer crap is lower
