Old 03-15-2006, 10:02 AM   #1
the swede
Hallo over there!
I have problem with my AC. When I push the button nothing happens. I can see that the compressor don´t start.
Can it be a fuse or something?
Maybe there is a leak and the pressure is too low and it´s because of that it won´t start?
Can I check myself if the pressure is too low?
Or anybody have another suggestions what it can be?
Thanks from "the swede"
Old 03-15-2006, 11:50 AM   #2
AGT
AGT's Avatar
Few things it could be....does the light come on when you hit the A/C button? If so the have you checked the pressure at the blue line with a gauge? you can get an A/C refill kit that comes with a guage.
Have a good day
Old 03-15-2006, 11:55 AM   #3
the swede
Yes, the light come on when I push the A/C button.
I don´t know were too check the pressure?
Old 03-15-2006, 01:16 PM   #4
AGT
AGT's Avatar
There will be a couple silver colored 1/2 tubing going on the passenger side under the hood....check for a blue valve cap. unscrew and have the guage ready. 1st try starting the car and then opening the hood and hitting the A/C button. Listen for it to start up.
Have a good day
Old 03-16-2006, 06:34 PM   #5
flalero
Does the AC work on the high settings, but not the low settings? If this is the case, then it is the blower motor resistor. About $20 at a local parts store.
Old 03-16-2006, 07:40 PM   #6
CTS21
Hello,
Another thing you might want to consider is that the A/C wont turn on till it reaches around 15 degrees celsius outside. I was told this by a GM mechanic.
