Closed Thread
Old 03-19-2006, 09:14 PM   #1
2fst4u
[boosted 2.4L]
2fst4u's Avatar
did you guys use your stock 2.4 throttle bracket after you swapped for the 2.3 intake manifold and throttle body? did you have to grind the thing so it fit in the new location? i can't get my throttle cable to be long enough.
help please.
pictures too if you would.
i want to double check where all of the vacuum lines go to.
2fst4u is offline
Old 03-19-2006, 09:59 PM   #2
Oldsman
Owner
Oldsman's Avatar
i used a 2.4 TB so everything hooked up just fine.
Beware of the BackStabber
Oldsman is offline
Old 03-19-2006, 10:17 PM   #3
2fst4u
[boosted 2.4L]
2fst4u's Avatar
greeeeeeat. even the "dictionary of the 2.4" doesn't have an answer.
2fst4u is offline
Old 03-19-2006, 11:00 PM   #4
Oldsman
Owner
Oldsman's Avatar
here you go
To mount the throttle cable bracket, I would first get one off a '95 2.3(part #
22590179. This part is now discontinued by GM), just because it was made to fit in the J-body with this intake
manifold. The upper bolt hole in the t/b will need to be taped, to bolt the
upper part of the bracket in place.
Oldsman is offline
Old 03-19-2006, 11:01 PM   #5
Oldsman
Owner
Oldsman's Avatar
go here for more info
http://www.quad4forums.com/forums/showthre...=&threadid=3252
Oldsman is offline
Old 03-19-2006, 11:36 PM   #6
2fst4u
[boosted 2.4L]
2fst4u's Avatar
yeah, i just saw that too. thanks for the help. i guess i'll be junkyard hopping to find that bracket. thanks.
(this thread can be locked)
2fst4u is offline
Closed Thread
