Old 03-21-2006, 02:04 PM   #1
63starfire
Hey, I totalled my white '99 coupe a couple of months ago and now bought a black '00 coupe. They both had/have the 3400 but my new one has "california emissions" on it. I was wondering if anyone knows what that even is, and if and how it affects performance etc.
Old 03-21-2006, 02:05 PM   #2
ask redog, he's the only one that i can remember that also has cali emmissions.
Old 03-21-2006, 02:42 PM   #3
Your car has an air pump right behind the right side headlight, extra fuel rails, and tighter O2 sensors.
If you're at sea level and drive up the Mts, you're SES light will most likely come on, due to the thinner air.
This system keeps a tighter emissions on the car. The air pump psuhes air though the heads, and keeps the heads combusing at a cooler temp to reduce emissions.
You can still mod out the car, but changing the cat will require a O2 sim. If you buy P&P heads, you will need "emission heads" due to the extra ports fro the air pump system.
On a 2000, HP loss is minial if at all. All the mods I have done, and the car always passes inspection with flying colors, in the 2nd most strict state, inspection wise. (2nd to California)
Old 03-21-2006, 04:30 PM   #4
SilverBullet256
Senior Member
SilverBullet256 is an unknown quantity at this point
Send a message via MSN to SilverBullet256
cant you just get heads from a regular engine and then swap it on to get rid of the cali emissions?, or didnt you try that
SilverBullet256 is offline   Reply With Quote
Old 03-22-2006, 12:51 AM   #5
^^^ Tried it, It doesn't work because the air pump pumps air into the heads, without it the car cannot be reg in PA, plus the possiblly of overheat since the car is set up that way
Old 03-22-2006, 09:45 AM   #6
63starfire
Awesome thanks, and I'm in Minnesota where we don't have inspections so that's not a concern
