Old 02-20-2004, 03:13 AM   #1
ALero rulez
The light been on for awhile now. I took to autozone to get it checked out it sound it had a misfire and cy4 so i bruoght new wire and plugs but the light didnt go off any suggest guys?
Old 02-20-2004, 07:10 AM   #2
3.4Alero
could be a clogged or bad injector.
Old 02-20-2004, 09:08 AM   #3
Insane75
what he said.
Also what engine do you have cause my 3400 did this and it turned out to be the EGR valve.
Old 02-20-2004, 09:16 AM   #4
Modded Exhaust? If so O2 sensor by the cat
Old 02-20-2004, 12:13 PM   #5
Fast Eddie
did you have the light turned off and then it came back on or it just didn't turn off? If its the first then have the boob @ autozone remove the code, it will linger until removed, then you should be straight. Otherwise it COULD be your fuel system, but more likely it is somewhere in the ignition system. It is NOT the exhaust sensor, that is a different code, usually slow response or bad O2 sensor, forget teh actuall code but not a misfire.
I'm on a boat.....
Old 02-24-2004, 07:22 PM   #6
ALero rulez
i took my car to autozone and the guy told me it was a misfire in c4 i got the plug replace but it still misfires.
Old 02-24-2004, 07:34 PM   #7
^^^Does the car run rough? Does it lag on acceration? At wide open thorttle, does it lack sometimes and other time not?
These are some signs of misfireing
Old 02-24-2004, 08:19 PM   #8
freeze12
Check the Coils for any corrosion or tracking.
...Dan...
Old 02-25-2004, 12:33 PM   #9
loudalero
Yeah this just happened and it turned out to be the coil pack for number four cylinder and msd coil packs from summit are 39 a piece so you might want to try one or just get a stock replacement at autozone.
Old 02-26-2004, 02:33 PM   #10
ALero rulez
it lags just alittle but u said it might be a coil so I can buy from autozone and replace it myself right
Old 02-26-2004, 04:36 PM   #11
freeze12
Yes...You can buy a Coil from Autozone. When You check each Coil, look for carbon tracking,burning,corrosion...etc. as this can cause a misfire. also check the plug to the Ignition Module for any corrosion.
...Dan...
Old 02-27-2004, 12:58 AM   #12
Fast Eddie
did they reset the code once you replaced stuff or not? If they didn't it is just a latent code that is not valid, have it reset and see if it comes back on.
I'm on a boat.....
