03-23-2006, 06:07 PM
So i decide that this summer i am going to do one thing or the other and don't know which one to spend the money on. A) i can get my bumper and exhaust looking right or B) get a remote start system. Which one do you think i should do?
DO WORK
03-23-2006, 06:14 PM
I Have ONE NUT
Since you said summer you wont have to worry about comming out to the cold so, do the exaust. Then by the time winter comes around you might be able to do the remote start.
03-23-2006, 06:22 PM
Save your money for the next thing that will break!!!
03-23-2006, 06:59 PM
word....i wanted a CAI, muffler, and a radar. but i had spend 190 for a high amp alternator, 90 for rotors and 50 for pads. i hate alero stock everything!!!
New and Want to MOD
I have 2000 Red Alero
2.4L Twin Cam with 15" Tires
03-23-2006, 08:04 PM
i'm not worried about that. i have enough money saved that something like that won't be a problem.
DO WORK
03-23-2006, 08:29 PM
Originally posted by alerocar01+Mar 23 2006, 08:04 PM--><div class='quotetop'>QUOTE(alerocar01 @ Mar 23 2006, 08:04 PM)</div><div class='quotemain'><!--QuoteBegin-CTS21@Mar 23 2006, 06:22 PM
[/b][/quote]
well your askin for opinions......... id get that exhaust lookin better........ cause ya it looks pretty ghetto right now.
those tips stick out WAY to far
joelsoundxtreme: u faggot
03-23-2006, 08:42 PM
@Kutztown University PA
exhaust look right imo also
03-23-2006, 08:47 PM
Mile High Club
if all your going to do to the exhaust is shorten the pipes & reweld the tips .......that should only cost about $50
Its not like you should have to save up for it
03-23-2006, 09:57 PM
it hard to tell in the picture but the tips don't stick out that much. it is just hung so low it looks like that. if i do the exhaust i will need to cut the bumper and bring up the exhaust about 1"-1 1/2". yeah it that low. :Noooo:
DO WORK
03-24-2006, 12:55 PM
Originally posted by alerocar01+Mar 24 2006, 02:57 AM--><div class='quotetop'>QUOTE(alerocar01 @ Mar 24 2006, 02:57 AM)</div><div class='quotemain'><!--QuoteBegin-Mr_White@Mar 23 2006, 08:47 PM
[/b][/quote]
Easy DIY job.
I do not recomend cutting painted body parts but since this is so low no one will ever see if you make a mistake.
Just cut out a spot with a dremel, easy to do, not much to explain.
The exhuast, just use zip ties on the hangers to pull it up higher, thats what i used to get my tips up higher, no one will EVER see the zip ties.
Done, price? $1.00....for the zip ties.
03-24-2006, 06:24 PM
wow you are not serious are you?
Brent: and in the end...... cherrington is still a cum dumpster whose closest contact with HOT women is through a car internet forum ........... so as long as we can agree on that........ we can all go back to being friends.
Being Brents friend is teh hotness
03-24-2006, 06:55 PM
uh...ok. That's one way, then there's also the RIGHT way.
and my opinion is get the exhaust fixed, the angle the pic is from is a prominent angle that most people WILL see the car from and it will look like they hang that low or stick out that far. Were you standing in an upright position when you took the picture?
03-24-2006, 07:19 PM
yeah
DO WORK
03-24-2006, 07:24 PM
then that's what people will see too.
03-24-2006, 07:25 PM
good point.
DO WORK
03-25-2006, 09:29 AM
Why would i not be serious?
Look at my exhuast tips, can see the zip ties? All you do is zip tie the hangers, works the same as buying new rubber hangers.
http://www.cardomain.com/ride/426149/6
http://www.cardomain.com/ride/426149/3
Also alot of grandam owners cut out the rear diffuser with dremels and they come out really good, it would work the same way for cuting out a notch for your exhuast.
03-26-2006, 07:26 PM
^^ I think they were talking about the zip ties and i don't know if i would want to do it that way.
DO WORK
03-26-2006, 08:30 PM
I've had my mounts ziptied for 2 years now. No different than buying new mounts and it doesn't cost anything. If anything else it will be a temporary fix and make your car look better.
03-26-2006, 08:35 PM
And as for the cutout, I used a dremel to do mine as well. I took a piece of cardboard and traced a pattern from the left side and transferred it to the right side. Even when you stand right behind the car it looks identical on both sides.
03-27-2006, 07:07 AM
Originally posted by SouthDakotAlero+Mar 27 2006, 01:35 AM--><div class='quotetop'>QUOTE(SouthDakotAlero @ Mar 27 2006, 01:35 AM)</div><div class='quotemain'>I've had my mounts ziptied for 2 years now. No different than buying new mounts and it doesn't cost anything. If anything else it will be a temporary fix and make your car look better.
[/b]
<!--QuoteBegin-SouthDakotAlero@Mar 27 2006, 01:35 AM
[/quote]
Thank god you replied to this thread
