Old 03-24-2006, 04:27 PM   #1
toddbobby
toddbobby is an unknown quantity at this point
I cleared my corners and i put amber bulbs in the corners now when my car is on they stay on and my passenger side blinker light stay on is this normal and if not how can i fix it?
toddbobby is offline   Reply With Quote
Old 03-24-2006, 04:38 PM   #2
WildBill
you might have put the bulb in wrong. some bulbs can actually go in backwards. check that and see. good luck
Old 03-24-2006, 05:17 PM   #3
toddbobby
I tried that and it did not work thanks any way. Any other ideas would be great thank you.
Old 04-21-2006, 02:25 PM   #4
BRalero01
bad connection is your only option man, if all you did was pull the bulbs, take them out and try um again, twist them, push them a lil harder. could check your fuses but i doubt thats any problem
Old 04-21-2006, 09:26 PM   #5
robz02alero
robz02alero's Avatar
robz02alero is an unknown quantity at this point
Send a message via Yahoo to robz02alero
Hey dude, make sure you put the right bulbs in. There are some bulbs that may fit but not the proper brightness. Check it out. Check all your other bulbs and your flasher too.
owner/operator of : The Pinnacle of Clean Auto Detailing Service www.pinnacleofclean.blogspot.com
Supporter of Aleromod.com
OIF VETERAN X3
COMING HOME SOON
robz02alero is offline   Reply With Quote
