Old 04-02-2006, 11:11 PM   #1
I want to replace the speakers in my door.... can I just pop that cover off that's over the speaker, or do I have to remove the entire door panel..... (please just the cover..... )
Old 04-02-2006, 11:13 PM   #2
jamcllw
entire door panel
Old 04-02-2006, 11:15 PM   #3
that sucks......
Old 04-02-2006, 11:32 PM   #4
violentrapture
violentrapture is an unknown quantity at this point
Send a message via Yahoo to violentrapture
Not really that big of a deal - takes seriously like 30 seconds to pull them off - mine are off/on so much I only have one screw in them. :P
violentrapture is offline   Reply With Quote
Old 04-03-2006, 12:53 AM   #5
1WhiteOSV
first pop off the oval shaped cover inside the door handle (center of door panel).....remove 2 phillips screws in there....then pull the bottom part of the handle off then remove the top part.............then take out the switch panel and disconnect all plugs from it..........then remove the reflector in the bottom corner of the door panel and remove 1 phillips screw from there.........then take off tweeter holder....then door panel just pulls off
