04-03-2006, 11:07 PM
have a 01 alero 3400 65k miles. every once and a while after driving, the car will jerk hard into 2nd, and then slightly jerk into 3rd. it will keep doing this until i shut the car off. if i turn it back on, it will stop doing it, but then will randomly start up the next day. is this the transmission going? was driving by an older female before me, some i hope the transmission isnt going, since i bought the car a week ago.
04-04-2006, 12:38 AM
the exact thing happens to me. When the car is cold it runs very smoothly but when it gets to normal temps (around the half way point on the temp gauge) it starts getting jerky. I'd also like to know more about this.
04-04-2006, 02:50 AM
Senior Member
add transmission fluid, easiest thing you can do to try to fix it, i had the same problem and then eventually it started slipping between first and second so i added a quart of tranny fluid and its smooth as new now, so first try putting a pint in and drive it for a while, then add another pint if you are still having problems
04-04-2006, 06:59 AM
At 65k, you should have the trans fluid flushed. I doubt the trans was serviced before you got it.
2005 Honda CR-V AWD
04-04-2006, 10:18 AM
thanks for the replys, ill try it out this weekend
04-04-2006, 05:08 PM
Senior Member
i was told just add some around 65-70 k and then around 100 k have it flushed
04-23-2006, 02:34 PM
Just wondering if you ever got your issue fixed?
2005 Honda CR-V AWD
04-23-2006, 03:20 PM
Not yet. I'll replace my trans fluid soon enough; i'll post here about any results afterwards
04-24-2006, 12:29 PM
flushed mine or at least most of it at 50k miles
AUTOBOT
04-24-2006, 01:01 PM
I'm thinking about getting my flushed and renewed soon..... i got my car used at 75000 and im not too sure if they changed the transmission fluid at all...... do you think i should just change it to be safe? i'm thinking about getting royal purple tranny fluid....
04-24-2006, 01:56 PM
It's always good to do PM work on a car, but this isn't something you can do youself.
The tranny holds 14 quarts of fluid, if you drop the pan, you only get out 3 or 4 quarts, it has to be hooked up to a machine to get all of it out of the convertor and other tranny places.
I wouldn't use royal purple. I've heard that is doesn't good too much good for a GM transmission. Stick with the GM OEM fliud. It's the best thing for the car
04-25-2006, 02:33 AM
Well, the OEM fluid is Dexron III, so any fluid meeting that spec would be good. I myself would go with Mobil1. You can also flush all the old fluid out by disconnecting one of the cooler lines and routing it to a container, then start the car and fill the trans while it pumps the old fluid out. You'll see a color change when all the old stuff is out.
04-25-2006, 08:47 AM
hmmm i see, hoepfully this isn't too costly to get it done professionally?
