02-22-2004, 05:46 PM
I currently have two tubes on the underbody, i have been just buying those single tubes at autozone for about $35 each when I get a little extra cash on the side...I currently have the front one mounted behind the plastic guard piece and the back light tied down with some metal wire. I am curious as to where everyone has mounted their lights as I dont like the current spots due to fact of not enough light being shown (that plastic guard on the front keeps it from showing at all in the front, just on the ground) and it looks like im stuck with the back one where it is....any help please?
02-22-2004, 07:10 PM
alright....here are where mine are. The front one is bettween the plastic peices I'm guessing where you have yours...there is no other place you can put it in the front if its where I'm thinking. In the back I got mine right about the exhuast pipe...it shines to where i want it too and you cant see the tube in less you get down on all 4's. I'm sure silent will post a response maybe he can explain it better than me.
02-22-2004, 07:31 PM
Kitteh is back!!!!
Ok here's a breakdown
Front tube - Goes behond the black plastic guard but as far back as it can go so you get a good amount of light past it.
Passenger side tubes - This goes behind the rail you use to jack up the car It fits behind perfect so no trouble here
Drivers side - Ok heres a little work, same deal goes behind the spot where you jack up your car. BUT in the back here you have your fuel lines that get in the way. Best method around this in there is a little rubber triangle that mounts themm and there is a little room to cut the rubber off to fit the tube better. Then youll still have about 1/4" of the tube sticking out the back. Id advise taking some electric tape or get something to cover over the tube so you dont see it.
Back tube - Basicly fit it around ytour exhaust in any way you can. Everybody has diff exhausts so its really based on what you have.
97 Nissan 240sx - sr20det
94 Nissan 240sx convertible
01 Suzuki gsxr 750
02-22-2004, 08:52 PM
I am BeerMan
For my back tube I mounted a bracket on each spot where the 2 bumper bolts are. It's hides up there pretty good too
02-22-2004, 09:59 PM
hmm i think i did my front differently. i cut two holes way up on each side of the plastic just above the grill in my bumper and put ech end of tube into hole. i dunno if thats why u guys do too or not
02-23-2004, 03:06 AM
I did mine the exact same way silent did. Worked out real well. Good luck getting light through the front bumper without doing some surgery.
03-08-2004, 07:28 PM
I did mine similar to Silents, however, if you are looking to get light on the ground in the front and want to be able to see the tube somewhat when a distance a way just take the clips that come with the bulbs and slip bulb up between bumber and a.c. unit or radiator, there is a plastice piece of your bumper there that curves up. Just slip wires by foglights place there and get some self tapping screws and screw right up into that plastic. My looks pretty tight when on can't see when close but 10ft or further back you can see bulb. (This suggestion not recommended if trying to avoid PD), I've been pulled over a couple times (just warnings!)
03-08-2004, 09:42 PM
Kitteh is back!!!!
i just did my iceled kit...very unique install i might add. ill take pics.
btw its abitch working around hydraulic lines on the sides
01 Suzuki gsxr 750
03-09-2004, 12:47 PM
yup yup.........i installed mine the same way......it worked out nicely......
03-09-2004, 01:21 PM
Kitteh is back!!!!
i gotta take clearer pics but heres the iceled
01 Suzuki gsxr 750
03-09-2004, 02:52 PM
Just don't do what the ricers do around here, use zip ties and put them right under the door where you can see the tube.
Can you say ghetto?
03-09-2004, 05:05 PM
Definitly a better pic, or possible a video??
03-09-2004, 05:12 PM
Kitteh is back!!!!
yea i can take a video tonight,
with the car layd out it sucsk all the light up on the side tubes, plus ignore the fact im missing my front bumper
01 Suzuki gsxr 750
03-22-2004, 02:55 PM
so was there ever a video?
03-22-2004, 03:03 PM
Kitteh is back!!!!
yea...actually ill be taking a vid tonight or tomarrow again since i cleared out my camera...but id rather wait till everything in the car is good to go...so maybe next monyda..ill see what i decide tonight
01 Suzuki gsxr 750
03-22-2004, 03:48 PM
I made aluminium brackets for mine.(the front and back)
